Originally posted by rangercarp Could this be some sort of built in polarizer?
I think not! This polarizing element is very thin and flexible and is used to split the light beam so as to achieve a low pass filter effect.
" [0078] As described above, according to the embodiment, the polarizing optical element 300 and the optical low pass filter 500 which are inexpensive and easy to manufacture, and are adapted for increasing the area thereof are provided. Since the polarizing optical element 300 and the optical low pass filter 500 are light in weight, has a high degree of flexibility and is easy to bend, polarizing optical element 300 and the optical low pass filter 500 can be advantageously accommodated in the photographing apparatus and have the advantage that the surface processing and so on can be applied easily. Therefore, the optical low pass filter 500 is suitable for use as an optical low pass filter for a photographing apparatus. "
