Originally posted by taowang No built-in flash on full frame body, which is bad, as it's the easiest way, if not the only way, to trigger the single off-camera external flash with P-TTL support.
As others, I believe omitting the pop-up flash is a good idea.
The pop-up flash cannot be put to serious use anyhow. It is too weak to function as a good controller over larger distances and recent Pentax DSLRs cannot use it to control off-camera flashes in HSS mode.
Regular P-TTL off-camera flashes can still be triggered by mounting a P-TTL flash on-camera.
I'd be using a radio trigger only, remote controlling off-camera flashes manually. Way better than fiddling with P-TTL anyhow.
I can't see Ricoh surprising us all with an RF-based flash system. Someone should open up an FGZ II flash and peek around for the RF antenna, anyhow.
Originally posted by taowang no Mic and Earphone port, these might suggest there is no video recording support on the full frame body;
I agree with Wired that these are surely hidden by a flap/door.
The more I look at the FF model design, the more I like it. Nice mix between the compactness of a K-3 and the stately / professional appearance of a classic MF camera.
I would welcome if it were a bit bigger than the K-5 / K-3. I love my K-5 II, but if it were a bit bigger, it would fit like a glove, as opposed to something that I have to slightly accommodate to.
