Originally posted by clackers I find EVFs overrated, Acg.
I have an A7 and you can't trust focus peaking on it.
that's because you don't know how to set up the evf.
it's been covered in this thread, i think?
Originally posted by clackers Magnified focus only does the same job as Live View on a DSLR.
no, it doesn't, because evf is oled under a hood, and live view is a washed-out lcd display, that you have to hold at arms length to use.
not comparable at all.
Originally posted by clackers The WYSIWYG is false - an 8-bit JPEG rendering that doesn't express the true dynamic range,
i don't know about that, but most in-camera histograms are based on jpeg preview.
so if you think that wysiwyg evf isn't right, then you certainly can't be using the in-camera histogram either
Originally posted by clackers and it gets so dark when you close down the aperture for flash photography it's like you still have the lens cap on - you have to go into a menu and turn on an artificial light level.
wrong, the light from the flash is accounted for when "setting effect ON" is chosen in the menu, which is the wysiwyg mode.
you need to learn how to use your camera... assuming that you actually own any sony cameras, that is
