Originally posted by Rondec
It does seem odd to me, Jay, that on one side you beat the drum that full frame is better for the small improvement you get in your image quality from it and then you say that you should mount cheap lenses, some of which are known to have weak borders and borderline performance on that expensive camera.
Which lenses have I advocated that have 'borderline performance'?
And you should know I'm not advocating 'cheap lenses', I'm advocating 'good lenses' -
good lenses just don't have to be expensive.
The lessons you or anyone should take here is that:
1) These days IQ can usually be improved more by using good lenses on a great sensor than great lenses on a worse sensor, and
2) The delta in quality between 'good' and 'great' lenses is often very small, smaller than the difference between, say, sensors of different sizes and same gen
3) It generally costs more to chase great glass than it does to chase great sensors, and the returns diminish faster with 'great glass'
I should point out that everyone's idea of what's 'good' vs. 'great' is different, though. If I were to qualify what I mean,
Good: FA 50 f/1.7 Great: Zeiss Planar f/1.4
Good: Tamron 28-75 f/2.8 Great: Nikon 24-70 2.8
Good: Tamron 70-200 2.8 Great: Nikon 70-200 2.8 VR II
Quote: If I am going to spend close to 3 grand on a body, I want to get maximum out of it.
The problem there is to get the 'maximum' out of it you could easily spend another $6 or $8K in one shopping trip. I'm here to warn you that $6K-$8K just might not be worth it to you, when all is said and done. 'maximizing' things just means travelling all the way down the existential, shrinking funnel of diminishing returns to the very end, and realizing you ended up only three feet from your comfortable stopping point
