Originally posted by osv lol... beyond that, the effects of cropping on dof:
"DOF is determined by subject magnification at the film / sensor plane and the selected lens aperture or f-number. For a given f-number, increasing the magnification, either by moving closer to the subject or using a lens of greater focal length, decreases the DOF; decreasing magnification increases DOF. For a given subject magnification, increasing the f-number (decreasing the aperture diameter) increases the DOF; decreasing f-number decreases DOF.
If the original image is enlarged to make the final image, the circle of confusion in the original image must be smaller than that in the final image by the ratio of enlargement. Cropping an image and enlarging to the same size final image as an uncropped image taken under the same conditions is equivalent to using a smaller format under the same conditions, so the cropped image has less DOF. (Stroebel 1976, 134, 136–37)."
Stop moving closer to the subject and changing one of the primary defining properties of DOF!
Stop changing the focal length, again changing one of the primary defining properties of DOF!
Until there is an understanding how DOF is perceived on the sensor plane, the rest of the statements are useless.
Once you keep the primary factors consistent, only then you can then start talking about what it means to create an "equivalent image" from that. How it changes in cropping FF down to the Cropped portion, or magnifying the Cropped image unto the FF size. Effects of printing, resolution, substrate, acceptable sharpness, viewing distance and even visual acuity of the individual viewing the image.
---------- Post added 07-16-15 at 04:11 PM ----------
Originally posted by boriscleto T-Rex, Giant Death Chicken.
NICE! Will I be able to get pictures like that with a FF camera?
