08-01-2015, 05:25 PM   #31
falconeye's Avatar
QuoteOriginally posted by GUB Quote
A question here - (not an argument) are the OOF areas equally identical , ie is the potential for bokeh the same?
At equivalently chosen parameters yes, with sufficiently abberation-free lenses.
There really is now way to tell the difference.
It isn't just the depth of field is the same, the bokeh (i.e., rendering of out of focus point light sources into defocus disks) is the same too. Of course, real lenses don't always render perfect disks which leads to differences in the bokeh. But these differences don't exist for ideal lenses.
The fastest way to understand the reason why this is and avoiding any math: Bokeh is a parallax effect, the left edge of the lens seeing from a slightly different perspective than the right edge of the lens. And this effect depends on the distance between the two edges (and distance to the subject) and nothing else (especially not sensor size). This edge distance remains a constant if the aperture diameter is kept a constant, i.e., if fstop is scaled with 1/crop factor (because this is what you scale the focal length with).
08-01-2015, 05:29 PM   #32
GUB
GUB's Avatar
The canon links I shared seemed like it.
Thanks for that.
---------- Post added 08-02-15 at 12:30 PM ----------
Thanks
24x36mm, 31mm, angle, bokeh, camera, degrees, discussion, disks, field, frame, full-frame, lens, lenses, model, pentax, record, scene, sharpness, test, thanks, view, words
Lens color rendering and white balance biz-engineer Photographic Technique 10 03-16-2015 02:18 PM
Rendering vs sharpness ChristianRock Pentax SLR Lens Discussion 20 05-07-2014 01:28 AM
No more lens clubs in the discussion thread Igilligan Site Suggestions and Help 75 01-12-2010 03:44 PM
Error with thread in lens discussion clawhammer Site Suggestions and Help 4 09-18-2007 09:47 PM
Make the Lens Discussion forum open to all... carpents Site Suggestions and Help 9 09-09-2006 05:28 AM
All times are GMT -7. The time now is 05:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
