09-14-2015, 02:13 PM   #1
FF in crop mode for astro
Assuming the FF can do crop mode, it would make sense (if the pixels are larger) for the FF to produce better results in low light and therefore astro
Regardless the FA 31mm + FF should be interesting for astro
your thoughts?
09-14-2015, 02:51 PM   #2
Not sure why you'd want to crop; a FF sensor utilized to its fullest works wonders for astrophotography. The 31mm would indeed be a nice wide lens to use for starscapes.
09-14-2015, 03:52 PM   #3
Emperor and Senpai
VoiceOfReason's Avatar
Even in crop mode the pixels will still be exactly the same size.
09-15-2015, 02:55 AM   #4
My widest glass is crop - 15mm DA, 16mm Samyang f2
Next widest is the FA 31
---------- Post added 09-15-15 at 10:58 AM ----------
QuoteOriginally posted by VoiceOfReason Quote
Talking about the pixel size physically on the sensor, should be a different number of microns to the K-3 ii for instance... the question is how much different and bigger
09-15-2015, 06:12 AM   #5
Fogel70's Avatar
QuoteOriginally posted by Conqueror Quote
The ISO advantage you get is mostly because of the larger area of the FF sensor, cropping to APS-C would make ISO performance equal of APS-C sensors.
A 24MP FF sensor cropped to APS-C (10MP) would give you same level of noise as on Pentax K-3 II.
Or a full 24MP FF images would give you similar noise level on ISO 6400 as you get on a Pentax K-3 II at ISO 3200 as the FF sensor is 2.25 as big as the APS-C sensor in K3 II.
If the generation of the sensors differ much it would of course alter the mix as sensor performance improves over time.
09-15-2015, 08:29 AM   #6
Exactly what the gentleman above me said. A cropped FF is the same as an APS-C if the pixel pitch is identical. If it's higer, then you get less noise per pixel, but that could be countered by scaling the APS-C image down. So, no - it doesn't help you unless you use the full sensor area.
09-15-2015, 10:36 AM   #7
31mm is a little long, in general, for astrolandscapes. If you want to do single exposure astrolandscapes then the 500-rule has you reaching for a fast, wide (below 20mm on FF) and sharp at wide-open MF lens.
24x36mm, astro, camera, crop, crop mode, dslr, ff, ff in crop, full frame, full-frame, mode, pentax, photography, sensor, size
How does a FF work in crop mode? Albermarle Pentax Full Frame 54 12-29-2015 11:28 AM
Just Realized With the FF We Can Scope Our Cameras for Astro Sagitta Pentax Full Frame 6 05-24-2015 02:21 AM
What will the crop mode be like on the FF? mikeodial Pentax Full Frame 19 05-08-2015 08:59 PM
(un-)importance of crop mode for FF ?!? Arne Bo Pentax Full Frame 54 03-21-2015 02:11 PM
Will Pentax FF have a APSC crop mode?? COULDBE2 Pentax SLR Lens Discussion 22 10-29-2012 06:33 PM
All times are GMT -7. The time now is 04:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
