07-13-2016, 11:56 PM - 1 Like   #76
noelpolar's Avatar
QuoteOriginally posted by CypherOz Quote
Pentax needs a big price drop on glass.
in Australia, we need another China/India driven mining boom along with some other "loss of confidence in USA thing"..... then the lenses might be more reasonably priced for us.
08-03-2016, 05:28 PM   #77
Interesting
QuoteOriginally posted by npc Quote
Unless Ricoh officially confirms this no DA lens should be considered FF compatible.
Just consider the fact that for all the DA lenses sold trough the years nobody did any QC on FF so as long as they were OK on APS-C they would pass, even if decentering or other defects would make them unacceptable on FF. Same is valid for the teleconverter as well.
I've sold my DA 35 2.4 long before I got my a7r so that's the only one I did not test myself on FF. The other DA primes listed here (my own copies) covered FF without much vingetting but there is noticable drop in sharpness outside the APS-C zone (minimal on DA 70 ltd) , especially the extreme corners which are noticably worse than the same focal length old FA/A/etc lenses. Same for DA 40 ltd that I don't see listed above (it convers FF completely) - sharper in the APS-C zone, but much worse in the corners than the old M 40.
I'm not saying that they are unusable on FF but if they were sold to me as "FF lens" then definately I'd want my money back...
For the DA* 60-250 as I've mentioned elsewhere in the forum - I got rid of the dark corners on FF completely by removing the rear baffle - then sharpness is OK across the frame and does not have that sharpness falloff in the corners like my DA primes.
Well I just dropped a grand to buy the DA*200. All I can say is when I got my 16x20 enlargements back, Heavens to Mergatroid!!! Purple Fringing. That's a thousand dollar disappointment!!!
08-03-2016, 10:22 PM   #78
QuoteOriginally posted by JimBrennan Quote
You could have read reviews (there the same ussues on APSC) and yoyu could also enable the corrections so that it is simply removed..
12-08-2017, 07:52 AM - 1 Like   #79
Graphs in first post have been updated.
07-26-2018, 11:49 PM   #80
Always nice to find a updated version of FF K-mount lens line-up.
Thank you so much!
10-15-2019, 06:30 PM   #81
Leumas's Avatar
You know just an observation, but to me the amount of APS-C lenses that are projecting a FF image circle is actually kinda disconcerting in a way. It tells me they could have optimized the size better and perhaps even reduced cost with less glass.
If I have an APS-C system I want the smallest lenses I can have for that sensor, instead of lugging around FF compatible stuff. IMO
10-16-2019, 05:07 AM - 1 Like   #82
bdery's Avatar
QuoteOriginally posted by Leumas Quote
This thread is many years old, but here goes...
Optical designers have reasons for the choices they make. In the present case, creating lenses larger than the strict image circle they are tryinhg to illuinate has a few advantages:
1-lets the SR system move things around while still creating an image
2-diminish the effects of aberrations (mostly spherical but others will be impacted too)
3-reduce vignetting
Trust me, no optical designer will include useless glass in their design. It's expensive to purchase, process and assemble.
05-01-2020, 02:05 PM   #83
I believe this thread has answered a burning question I have worried about for a while now.
So my lenses from my super a and lenses from my K5 being A ,AF and DA should all work on the K1Mkii? In some form or other.
I am getting the K1Mkii later this month along with the HD D FA150-450mm f4.5-5.6 ED DC WR so it’s nice to know I can at least give them a whirl
And decide if they are good enough.
I have loads of them ��
05-02-2020, 03:11 AM - 1 Like   #84
angerdan's Avatar
QuoteOriginally posted by Falcon Quote
Yes. As you're used to.
DA mostly with vignetting due to the bigger sensor format.
FA with even faster AF due to the stronger AF-coupling motor.
05-02-2020, 08:06 AM   #85
monochrome's Avatar
QuoteOriginally posted by angerdan Quote
DA lenses can be used in Crop Mode (default) on K-1 / K-1ll. There won’t be vignetting but the resolution will be about 15.8Mp, about the same as a K-5.
05-02-2020, 01:39 PM - 1 Like   #86
Seeker of Knowledge
aslyfox's Avatar
Full Frame Coverage of DA Lenses: Comprehensive Test
Which DA lenses cover the full 24x36 mm frame?
Full Frame Coverage of DA Lenses: Comprehensive Test - Gear Guides | PentaxForums.com
might worth the time to review
05-02-2020, 02:15 PM   #87
normhead's Avatar
That looks like an absolute mountain of work you did there. I'm impressed by your dedication.
24x36mm, fa, fa*, fa-j, ff lenses overview, fisheye, full-frame, kleinbild, lenses, macro, pentax, pentax-k, pentax-k ff lenses, reflex, small format
Current Pentax Lenses - Cover FF or No? IsaacT Pentax SLR Lens Discussion 7 02-02-2015 12:43 AM
Current lenses on a FF Lurch Pentax SLR Lens Discussion 10 01-06-2014 10:17 PM
Overview of Pentax Lenses thechumpen Troubleshooting and Beginner Help 5 11-06-2012 04:09 PM
Current DA lenses fit for FF? or not? soalle Pentax SLR Lens Discussion 15 09-23-2012 02:36 PM
All times are GMT -7. The time now is 02:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
