02-15-2016, 07:35 PM   #1
Tilt screen rationale
I figure all rumours need to start somewhere, so why not here. I was contemplating why the new tilting screen was designed the way it is. Here's what I think. It's actually feeding information to the ibis and has the ability (when turned on) to tilt/shift the sensor plane to enable any lens to be a tilt shift in all directions.
02-15-2016, 07:40 PM - 1 Like   #2
Easier explanation:
Tilting screens (like on the 645Z) can't pivot side to side.
Articulating screens (like on the K-S2) need to be flipped out.
The K-1's unique screen design addresses both these limitations
02-15-2016, 07:42 PM   #3
Easier, but much less fun.
02-15-2016, 07:54 PM   #4
how do you people think of this stuff? it's seriously mind boggling lol
02-15-2016, 08:30 PM   #5
QuoteOriginally posted by wibbly Quote
By you people I assume you mean geniuses.
02-15-2016, 09:13 PM   #6
QuoteOriginally posted by moray-eel-bite Quote
There are some interesting ideas there. But probably not implemented.
My mobile phone has about 12 tiny in-built sensors (proximity/gravity/accelerometer/ gyroscope/magnetic field/light/GPS/WiFi/NFC/ finger-print/ touch screen, and more). I could certainly imagine camera engineers coming up with ways to creatively make use of such tiny sensors in a big flippy LCD like the K-1's.
02-15-2016, 09:15 PM   #7
i thought the sensor for ibis only moved on two axes, is it even capable of tilting?
02-15-2016, 09:26 PM   #8
UncleVanya's Avatar
Olympus has five axis ibis. No reason Pentax can't go in that direction.
02-15-2016, 09:29 PM   #9
bertwert's Avatar
The screen is an interesting design...
02-16-2016, 06:23 AM   #10
Fogel70's Avatar
But all 5-axis stabilization still moves the sensor in 2-axis + rotation of the sensor.
That is enough for compensating for 5-axis of camera motion.
02-16-2016, 07:20 AM   #11
microlight's Avatar
This talk of ibis and feeding indicates the real rationale behind the design - it doubles as a bird feeding table!
02-16-2016, 09:37 AM   #12
I have actually had the same thought, that they could use the position of the screen as input for sensor position. But I figure that while it might not be that hard to implement, it is still not worth it.
02-16-2016, 09:42 AM   #13
i still highly doubt that the sensor will ever move towards or away from the focal plane. i believe fogel is right and that "5 axis ibis" means it can correct for 5 axes of camera motion, not that the sensor moves on 5 axes
can anyone actually verify this?
02-16-2016, 10:42 AM   #14
There's no need to verify, you are correct. IIRC the 2 "extra" axes means compensation for translation movement (horizontally and vertically), besides for angular (h+v) and rotational movement.
But the sensor is moving inside its plane, and the alignment must be very precise - or else.
02-16-2016, 10:53 AM   #15
A very neat idea - certainly gets you thinking - I'm wondering if, just taking it at face value, it wouldn't be useful in insect etc macro, where you sometimes need to put the camera places your head can't easily follow -but I've never used live view for macro,so I don't know how it would work in practise
24x36mm, bearings, camera, design, durability, feature, full-frame, pentax, pentax news, pentax rumors, screen, screens, shots, tilt, tilt screen, wonder
Current vs. previous lenses owned - rationale bpv_UW Pentax SLR Lens Discussion 26 07-25-2016 11:02 AM
Why we need tilt-shift screen. JimmyDranox Pentax DSLR Discussion 12 05-01-2015 09:34 AM
Device to attach phone to act as tilt screen (with Flucard) atomx Pentax Camera and Field Accessories 5 03-13-2015 11:16 PM
Tilt Screen or Not? rbefly Pentax DSLR Discussion 20 02-27-2014 09:28 AM
which camera with tilt screen adwb Pentax Compact Cameras 13 11-15-2013 02:47 AM
All times are GMT -7. The time now is 05:38 PM. | See also: NikonForums.com, part of our network of photo forums!
