02-18-2016, 06:13 PM   #16
QuoteOriginally posted by npc Quote
Does anybody know if the new/current lenses have these corrections built into their firmware and communicated to the camera like the focal length, etc?
Or are they are of the camera firmware (which means older cameras can't correct new lenses unless a firmware update is released) ?
---------- Post added 02-18-16 at 04:20 PM ----------
Isn't this list little longer than 14 ?
Then whoever was counting was wrong Where was this info posted?
It sounds like these FA profiles are stored in the camera itself.
Unlike FA lenses, DA lenses contain correction profiles in their circuitry and communicate them to the camera.
02-18-2016, 07:30 PM   #17
FA* 24mm, FA 28mm, FA 31mm Limited, FA 35mm, FA 43mm Limited, FA 50mm F1.4, FA 77mm Limited, FA* 85mm, FA* 200mm, FA* 200mm Macro, FA* 300mm F2.8, FA* 300mm F4.5, FA* 400mm F5.6, FA* 600mm, FA* 28-70mm, FA* 80-200mm, FA* 250-600mm.
Pentax FA Prime Lenses - Reviews and Specifications - SLR and Interchangeable Lenses - Pentax Lens Reviews & Lens Database
Pentax FA Zoom Lenses - Reviews and Specifications - SLR and Interchangeable Lenses - Pentax Lens Reviews & Lens Database
Is it sad that I have all but one of those? Soon it will be time to dust them off!
Also, the DA* 200mm, DA* 300mm, and DA 560mm support lens corrections in full frame mode. Other DA lenses only have corrections in crop mode.
Cool!
I have FA 31mm Limited, FA 35mm, FA 43mm Limited, FA 50mm F1.4, FA 77mm Limited, FA* 85mm, FA* 80-200mm
I wonder if the F*300 will equate as the FA*300/4.5
Can't wait for the price of the FF to be announced locally.
02-18-2016, 10:06 PM   #18
QuoteOriginally posted by Wild Mark Quote
2. Why not add the F series lenses to the K-1? I am biases as I have all of those except one
QuoteOriginally posted by pathdoc Quote
IIRC the FA's have something about their inbuilt circuitry that tells the camera stuff which the F's don't. Do correct me if I am mistaken.
I want to say that the F lenses would give enough info for the body to identify them, but not sure.
@Wild Mark
When you put an F lens on your DSLR and take pictures, does the lens name appear in the picture metadata? If yes, that should be enough to identify it and make the correction profile selection theoretically possible.
02-19-2016, 02:39 AM   #19
vrolok's Avatar
But then FA 50 and FA 35 ain't either, they are still on the lens roadmap
Yep... I stand corrected
02-19-2016, 03:14 AM   #20
Saaaad? Why?
Surely you jest....
02-19-2016, 05:01 AM   #21
OK, then there is a chance that the F series can be treated the same as the FA series. I'll check to see if the camera imprints F series lenses in the exif data
02-19-2016, 10:10 AM   #22
bilybianca's Avatar
Isn't it sadder that I only have two of them? Why isn't the FA 20mm in there making it at least a triplet for me?
Kjell
02-19-2016, 10:16 AM   #23
bertwert's Avatar
QuoteOriginally posted by bilybianca Quote
Isn't it sad I've got none of them?
02-19-2016, 12:23 PM   #24
It should, but according to the manual there aren't any profiles for F lenses.
02-19-2016, 01:23 PM   #25
Thanks Adam. Perhaps something Pentax can work on and update in due course.
02-19-2016, 07:17 PM   #26
Correct me if I'm wrong, but the lens profiles only matter if you shoot in JPEG. If you're shooting RAW, you apply the lens corrections in your RAW developer software. (I only shoot RAW, so this feature doesn't matter much to me for instance.)
02-19-2016, 09:28 PM   #27
QuoteOriginally posted by nater Quote
Yes that is my understanding too. I usually shoot jpeg and RAW at the same time. It would be nice to have 'better' jpegs without the need to go to RAW and process.
02-19-2016, 09:36 PM   #28
mee
This brings a situation into my mind with the forums.. starting in a few months, we'll begin to have reviews and images shot in both APS-C and in FF format with the same lenses. I suspect these lenses will behave differently on each system and thus will alter the reviews of them.
Therefore, Would you be willing to add identification format/system tags [APS-C] and [FF] to the reviews so we can know from what reference point they are discussing?
Of course, those of us in the know, understand that before a certain date those ones were not FF. However, anyone can draft a new review and not mention the camera from which they used as the base of their lens review. Having tags that are mandatory for the submission of a lens review could mitigate that to some degree.
My guess is the new 36MP FF sensor is going to expose some issues with a few (or more) of the older lenses..
02-21-2016, 12:22 PM   #29
It's even more complicated than that because some of us have been impure (as it were) and shot Pentax lenses on Sony or other bodies. So before, where FF did not mean Pentax, now it might or might not.
02-22-2016, 01:17 PM   #30
QuoteOriginally posted by mee Quote
Lots of interesting points made here and yes I certainly agree with the separation of reviews based on APS-C and FF.
However, I am of a different view re: FF sensor and legacy lenses. I think many will find the FF legacy lenses will actually perform better than expected. Reason - legacy FF lenses on the APS-C system were already being pushed to the limits. The 'sweet spot' concept on APS-C is a nonsense - rather, the APS-C format was actually accentuating the optical flaws inherent in the lens by oversampling the optical projection (i.e. lots of megapixels in a very small area) then enlarging that to a discernible viewing size thus enhancing the problems. With a larger sampling area, YES we will see edge detail not previously observed, but, we are now sampling the FF image circle (optical design) in the manner it was designed for. On this basis the optical flaws should be less apparent (although still there).
Of course I am only referring to the higher end lenses. Lower quality lenses will probably have issues.
200mm, 24x36mm, 300mm, camera, corrections, fa, fa*, firmware, full-frame, legacy, legacy pentax lenses, lenses, lenses have corrections, pentax
So...which lenses work with the K-1? Oakland Rob Pentax K-1 44 02-20-2016 09:57 PM
Do Pentax dslr have built in battery? Michael Piziak Pentax DSLR Discussion 32 09-20-2014 06:35 PM
How to use built in k-r flash with old lenses Afrikaners Pentax DSLR Discussion 7 06-06-2013 10:12 AM
Tamron 17-50mm 1:2.8 & k-x in-camera corrections jolepp Troubleshooting and Beginner Help 5 10-14-2010 08:26 AM
Newbie Which DSLR accepts legacy lenses? jrdhooghe Troubleshooting and Beginner Help 5 08-02-2010 08:13 PM
All times are GMT -7. The time now is 03:47 PM. | See also: NikonForums.com, part of our network of photo forums!
