Originally posted by Gimbal I have never even thought about looking at the histogram of the live view image.
Is that supposed to work, with any kind of accuracy?
What LV shows on the screen is (ok, at least K5IIs ) what the camera thinks is the correct exposure. It also takes into account any exposure compensation you dial in (you can see the screen goes brighter/darker if you change this) and the histogram is just calculated from the image shown on the screen.
Generally in Av/Tv/etc automatic modes it will try to match that exposure and the JPEG histogram will be the same if you take a picture as long as this exposure is obtainable with the range of settings the camera is allowed to set automatically. So in a way it is wysiwyg but only if you are not using flash and let the camera pick the settings. That's my experience at least.
However, if it is not possible to achieve that exposure (say you've boosted the ISO to max and the camera cannot pick high enough shutter speed) then the histogram still looks OK in LV, but the final image ca be severely under/over exposed (but there's indication on the screen that it cannot set the correct value). M mode of course it is totally disconnected from the dialed settings (except the exposure compensation value, but it has no effect in M mode anyway).
---------- Post added 03-09-16 at 10:14 AM ----------
Originally posted by jcdoss I'd also like to know if this is effective for Pentax Live View. I use the live histogram quite a lot on my Sony with adapted Pentax lenses and it works well.
No. Or actually it is similar to it if you have the "Live View Display" set to "Settings Effect OFF". If using "Settings Effect ON" then Sonys are way more accurate...except maybe really long exposures where during refresh it cannot collect enough light to accurately simulate what the end image will look like.
