02-27-2016, 09:31 AM   #16
maxfield_photo's Avatar
It's possible, perhaps even likely, that the transparent LCD is glued to the focusing screen with the same type of optical cement used to hold lens elements together in order to create an air free interface. It may be very difficult to separate the two. Who wants to be the first brave volunteer?
02-27-2016, 11:13 AM   #17
It's possible that you would not be able to change the focusing screen without damaging the camera. It's possible that you could change it very easily, but Ricoh Imaging simply doesn't offer any alternative (so far they offered different grid arrangements, useless now since the included screen can display all of them).
And anything in between
02-28-2016, 01:18 PM   #18
Jimfear's Avatar
Wait a moment, did you say full frame pro DSLR and not interchangeable focus screens?(!) Bummer, I hope there is some easy hack for this, otherwise it is a dead stop deal breaker. I have not been collecting fine pentax glass for 15 years in order not to be able to focus them with a micro prism screen. I guess you can't project that with the LCD...
03-03-2016, 06:42 AM   #19
Detailed spec sheet for K-1 specifically says the focusing screen is not interchangeable.
Detailed spec sheet for K1 says that focusing screen can be interchanged - Pentax Germany:
"Mattscheibe Wechselbare "Natural-Bright III"-Mattscheibe mit AF-Rahmen."
Pentax USA just has a neutral statement:
Focusing screen: "Natural-Bright-Matte III focusing screen"
No interchangeable screen, no MF fun...
03-03-2016, 06:58 AM   #20
pete-tarmigan's Avatar
QuoteOriginally posted by Kerrowdown Quote
I wonder if the Viewfinder Magnifier O-ME53 will fit on too.
Clicking on the "What's in the Box" tab on the Ricoh Imaging Canada site shows that "Finder Cap ME" is included. Since that cap came with the flagship APS-C DSLRs, which accept the O-ME53, the K-1's viewfinder should also accept the O-ME53.
PENTAX K-1?Cameras?RICOH IMAGING CANADA
03-04-2016, 04:57 AM   #21
Not a Number's Avatar
So it seems the Canon 70D EOS has an LCD screen in the viewfinder as well as a "fixed" focus screen. It can be removed but you need to remove a couple of screws first. And the screen is a different size and design from Canon's other screens.
03-05-2016, 02:21 PM   #22
retired sw engineer
reh321's Avatar
QuoteOriginally posted by fredralphfred Quote
The other half of "accurate focusing" is focusing on what you want, rather than whatever the camera happens to "notice." Pentax's track record in that regard has not been great. Also, AF doesn't work well with manual lenses, as you noted. I had hoped that one by-product of the full-frame camera would be the ability to take the traditional Pentax split-prism focusing screens.
I took several pictures today using a newly acquired Super-Takumar f/2 35mm lens nearly wide open and nearly at minimum focusing distance. That is the most difficult MF I've done in awhile, but with the aid of the "in focus symbol" I got it right. I'm now convinced that the "in focus symbol" is a more reliable help than split-screen ever was {my eyes are 68 years old and showing every year of it}.
03-05-2016, 02:35 PM   #23
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by pete-tarmigan Quote
Good catch, thanks for the heads up.
03-05-2016, 04:42 PM   #24
Also, I just noticed that the O-ME53 is listed on the K-1's Accessory tab.
03-10-2016, 06:07 PM   #25
Is it possible to have the K-1 focusing screen be plain without any grids AF points etc.?
I have been using the ME-60 plain matte focusing screen for years. I find having anything on the screen a distraction. I can focus manually better. For me the plain matte screen allows me to focus even better than using a split image screen.
03-10-2016, 06:31 PM   #26
https://www.pentaxforums.com/forums/190-pentax-k-1/316208-pentax-k-1-viewfinder-demo-video.html
You can turn the grid marking off to have a plain ground glass. If you turn off AF the point display too.
03-10-2016, 06:38 PM   #27
Thanks for that Not a Number.
05-10-2016, 06:20 AM   #28
Definitely not interchangeable on my K-1. Really too "bright" a screen to focus at all with super fast lenses (50/1.2, 100/1.8). The O-ME53 makes it possible, but not easy. Reality is focus confirmation or live view with focus peaking. Latter works really well with the large bright swiveling screen, but you're relying on IBIS when holding the camera away from your body.
05-10-2016, 06:33 AM   #29
QuoteOriginally posted by John Shriver Quote
Shots of the pre-production bodies seemed to indicate the usual retaining frame catch for the screen as on APS-C bodies. If you are willing to possibly damaging something can you confirm that the screen cannot be detached.
Perhaps a ND filter over the eyepiece or wearing sunglasses when using fast MF lenses would help?
05-10-2016, 12:37 PM   #30
What looked like a catch is definitely the mounting for an LED. The screen is totally surrounded by a rigid plastic frame. I think the hinged frame would not have cleared the much more complicated travel path of the mirror on the K-1.
24x36mm, full-frame, pentax, prism, screens
after-market focusing screens (Katz Eye, others) compared to manual film era screens Lititz Pentax DSLR Discussion 2 05-14-2014 06:47 AM
More details about the interchangeable focusing screens Basset Pentax K-30 & K-50 18 05-27-2013 02:39 AM
Why not genuine interchangeable focusing screens? tim60 Pentax Camera and Field Accessories 4 04-13-2013 09:34 PM
does the K5 support interchangeable focus screens nirVaan Pentax K-5 16 12-10-2012 03:08 PM
K10D interchangeable focusing screens and warranty question. pentaxbling Pentax DSLR Discussion 2 11-20-2007 02:04 PM
All times are GMT -7. The time now is 11:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
