Originally posted by npc Well, on digital a pixel is a pixel. Could be of different size on the sensor but once sampled to data it does not have a size anymore just a value. So you just have data. It could be 16mpx from aps-c sensor or 24 from FF sensor or something else but it does not matter anymore since it only measures the noise based on the pixel values. As the output pixels are the same size if you use the same output media for both images then really more mpx = bigger source image size.
Then when you know your what is your raw noise + your resolution and this gives you some idea wether you need to denoise and how much without losing too much details, how much you can scale and how much potentially you can crop to get to your target output media resolution of 8mpix while keeping sufficient image quality. If you just look at a normalized value then these things are harder to tell as differences are averaged out when you scale both images down. Just to take it to the extreme if you scale the noisiest possible 4mpix image and the cleanest possible say 24 mpix image to a thumbnail of 16x16 px probably you can't measure any difference anymore off the thumbnais. Then try to scale the same to 8mpix ...
Anyway, It is pointess to compare 2 different mpx sensors just for noise without considering their resolution as well and normalizing the images to a third size does not tell the whole story.
For same mpix sensors regardless of their size there's no need to normalize since they are already "normalized".
People compare output of sensors all of the time. "My K5 produces lots better images than my K7 did," or whatever. This is done without specific measurement, but more with a feel to how much you can push the RAW files you get from a given sensor at a given iso and then what size you can print that file at.
As to the fact that DXO Mark picked 8 megapixels as their normalization size, when they started their web site, 6 megapixel sensors were still pretty common. At this point, obviously most cameras have higher numbers of megapixels, but to adjust the normalization size, say, to 16 megapixels, would make it impossible to backwards compare cameras tested with the new normalization standard to those tested with the old one.
In the end, it is all about the print or the viewed image. The assumption has to be made that if you were taking a given image with whatever camera, your end size would be the same. Clearly in that situation, some sensors will perform better than others.
