Originally posted by rcolman Very nice shot! I particularly like the contrast of the white cliffs with the black starry sky. I do have questions and comments if you wish to continue this part on PM.
I would not agree with you about stacking. It is a routine part of both amateur and professional astrophotography, and would not be in such heavy use if it did not provide mega-benefits. In terms of noise and detail renditions, I can beat the "pants" off of any 2-minute exposure with a small number of stacked images. It is, however, a pain when including landscape foregrounds. Lucky for me my S.O. (significant other? starry other?) is a photoshop addict and does the hard part for me. I have also just started exploring "starry landscape stacker" on a Mac that emphases the foreground part, and easier to use.
I have owned the Tamron 15-30mm and rented the super-high price Pentax version. The performance is almost there for astro landscapes, but not quite. F2.8 is marginal. There is some astigmatism towards the edges of the frame. Worst of all, I can barely lift the lens + camera, which weighs in at about 4.5 lbs. let alone take it onto a hike.
Below, there is a K-1 image take with a tamron 28-70 zoom at 70mm (not exactly a "stellar" lens) using 60 sec exposures. In this case I had nothing better to do, since I was camped out and took the exposures right next to the car. So, this is 30 stacked images with no foreground to worry about. Notice the horsehead nebula peaking out? Not bad for a casual shot.
Very nice shot indeed.
I fully agree stacking works with deep space objects, and can work on the style of work I do, however I just find I can get by much better with the Astrotracer feature. I don't work the deep space shots, but for sure would be stacking on those. You are also right that the K1 and 15-30 is a heavy combination. But it's solid for sure.
There is a bit of variance in the 15-30's of all the lenses I have purchased, I have had more trouble with that lens. I need the 15mm side of things so rectilinear causes it's own set of issues.
For the work I do, mainly landscape, combined with Milky way, I just find the results much better. With Nikon I was forced to shoot at min 3200 or even 6400, with a faster lens. All of which means, coma problems, (which IMO look much worse than the slight trailing I see), noise, much more noise, DOF at 1.4 to 2.0 non existent. Causing a lot more work in the foreground. Stacking still creates a blurred foreground. You are correct on the F 2.8 vs F 4.0 and I do tend to stay more wide open now. The F 4.0 to 5.0 gain in DOF is lost due to the blur of the tracing. So an additional frame or two must be taken for that. I have tried many of the best 1.4 lenses for Nikon and really none of them are coma free, and the coma issue just ruins a shot at least for me. This true also for most of the fast Sigma glass, only the lowly Samyang (pun) can produce a coma free output wide open, but it's such a pain to focus. The best Nikon the D810A can do better but at 2x the cost of a single K1 and the D810A is rather limited for other photography.
I looked at the iOption, but again weight and setup at night were more than I was looking for, but again I agree results can be amazing. I may still go there but will still have the same issue with the wide lenses I need so for now staying with the Pentax feature.
Wasn't trying to state stacking is bad, by any means. I still stack for star trails all the time using partial moonlight for illumination and love the results, but it's a lot of work for a shot most people don't being to appreciate the time involved, and also now all believe it's fake. sad.
The advantages of the startracer just work better for me in the type of shots I am trying to produce.
Paul C
