Originally posted by HopelessTogger Lenses designed for digital and optimized for pixel peeping sharpness using newly designed coatings and lots of elements is what I think Yannick is getting at when he says "modern".
So the Distagon which is produced in the 1950's and typically has 11 elements must suck. Of the 3 Pentax Limited lenses the 43mm has 7 elements so it must be better than the 31mm which has 9 elements. The famous K 28mm F/2 also has 9 elements so it can't be as good either, yet the K 28mm F/2 sells for more used than the 43mm LTD does new.....
The less glass you use the better, but there is a lot more to it. The quality of that glass is probably more important. There are a lot of crappy lenses out there that have 6-9 elements. The Zeiss Otus 55mm has 12 elements. The Leica 28mm Lux has 10 elements. The Pentax M 28mm F/2.8 only has 7 elements and sells for $50.00, but it has almost the "optimal" number of elements so it must be better than the Leica, right? Do you really believe that?
