03-31-2016, 04:53 PM   #16
monochrome's Avatar
Well, I know that Pentax is being behind compare to other companies
You do? Where are they behind?
03-31-2016, 06:10 PM   #17
QuoteOriginally posted by rlatjsrud Quote
How do you define "behind"??
I switched from Pentax to Canon in 1995 because Canon AF system was clearly superior to what Pentax was offering.
I came back to Pentax this past year because while Canon lenses are still wonderful, their bodies are not.
03-31-2016, 06:51 PM   #18
Lens release and update speed
AF system
Flash system
No excuses
03-31-2016, 07:10 PM   #19
monochrome's Avatar
AF system
Flash system
No excuses
Maybe there's a different system . . .
You seem unhappy with Pentax on many threads.
Nikon has what, 200 lenses?
51 spread out AF points?
Best Speedlight system in the business for literally decades.
Of course Nikon is a bit spendy.
03-31-2016, 08:21 PM   #20
For the future future the XQD format is the best choice. XQD runs on PCI Express technologies for the interface bus which brings SSD types of speeds.
03-31-2016, 09:59 PM   #21
joergens.mi's Avatar
QuoteOriginally posted by Rico Quote
This means that the processor musst supply PCI-Express an must have the power to generate and distribute data at this speed. Is Milbeaut 7 or 8 capable of that?
And what happens when the sensor is the bootle neck?
It is really genious writing with 1 GBit/second when Data is coming Byte per Byte
Most items are for Quartet players only. It's interesting in the existing system to match the components optimally, to get maximum overall performance out off the system.
Primary target is a good sensor with high dynamics and low noise, this should be read as quick as possible, this read-out data should then be processed without adding any delays and then written immediately to the memory card. The writing speed to the SD-card does not need to be greater than the read-out speed of the sensor.
24x36mm, card, ff, film, full-frame, lens, lenses, ls, pentax, sd, technology for future, xqd
The future of GR cameras? ogl Ricoh GR 18 02-22-2016 10:53 PM
Super resolution by pixel shifting in future Pentax cameras Mistral75 Pentax News and Rumors 190 03-29-2015 04:31 AM
In-Mouth Cameras: The Future of Food Photography? RioRico Photographic Technique 2 10-15-2011 05:07 PM
Fantasy lens: 200-400mm compact F8 apo WR for high ISO future cameras p contor Pentax SLR Lens Discussion 2 05-29-2010 12:06 AM
New Technology meets old Technology. Pentax K10D / Ford Model A ebooks4pentax Pentax DSLR Discussion 2 01-22-2008 06:45 PM
All times are GMT -7. The time now is 04:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
