05-16-2016, 10:11 PM   #1
Clinton's Avatar
No lens profile for the DA* 55/1.4 on FF?
I'm still wondering why this lens isn't shown as a compatible with full frame, but in any event, why no lens correcting profiles for it?
05-16-2016, 10:50 PM   #2
QuoteOriginally posted by Clinton Quote
Correct, there are no in-camera profiles. The only DA lenses "officially" compatible are the 200mm, 300mm, and 560mm. Maybe Pentax's standards are way stricter than ours?
05-16-2016, 11:31 PM   #3
I guess the DA*55 is not recognized as FF lens because of vignetting wide open. DA*55 works great on FF when stopped down to f2.8, but... when used on FF, 55mm become a standard FL lens interesting to use edge to edge. When stopped down to f2.8, except for its smaller size/weight, there is little gain of using this standard FL over using the DFA24-70 set at 55mm f2.8. IMO, using the DA*55 on APSC/crop mode makes sense (=85mm equivalent portrait lens), but makes less sense to use it on FF for the same purpose. Also there is a new standard FL prime on the road map, that means from marketing standpoint, DA*55 isn't promoted for FF use.
05-17-2016, 01:05 AM   #4
RonHendriks1966's Avatar
Can we see an image of the vignetting with the da*55 set at F1. 4 to f2.8 ? Maybe the hood is also playing a part in this, so maybe take it off.
05-17-2016, 03:10 AM   #5
Na Horuk's Avatar
Maybe at least the third party raw editors will make FF profiles for these lenses.
05-17-2016, 04:49 AM   #6
There is a profile in Lightroom that seems to remove vignetting, although I wonder if it isn't an APS-C profile, it does seem to work with the DA 55 and K-1 combo.
This is a shot at f1.4. Tough with these shots because depth of field is so limited it is usually hard to judge edge sharpness, etc.
05-17-2016, 07:24 PM   #7
Clinton's Avatar
As opposed to the 560mm that needs to be stopped down below F8?
05-18-2016, 12:59 AM   #8
Not sure if you wanted to throw in some drama or if you remain objective. Objectively, with the D560, corners aren't that essential since the reason why people buy a D560 is for getting more reach even on crop body, hence usually not a problem to crop the edges on FF and not needing to stop it down to f8 or more.
24x36mm, full-frame, lens, lens profile, pentax
DA* 55 on FF rlatjsrud Pentax Full Frame 26 06-13-2016 05:15 PM
Better Portrait Lens? FA 77 1.8 vs DA 55* 1.4 reivax Pentax SLR Lens Discussion 83 01-02-2015 06:45 AM
DA* Lens Performance on FF (with [HD] 1.4x Teleconverter) Joshua A Pentax SLR Lens Discussion 3 11-01-2014 01:57 PM
For Sale - Sold: smc PENTAX-DA 1:4-5.8 55-300mm ED (Not DA L) Boxed DA 55-300 transam879 Sold Items 2 07-23-2014 07:41 PM
No lens profile for Sigma 10-20/4-5.6 coolguy1004 Pentax SLR Lens Discussion 2 06-23-2011 08:22 PM
All times are GMT -7. The time now is 09:06 AM. | See also: NikonForums.com, part of our network of photo forums!
