05-29-2016, 11:36 AM   #16
QuoteOriginally posted by seanix Quote
My K20D does not do this. This was the first thing I noticed on the K-1. Probably a lot of people like me are upgrading from older bodies like the K10D or K20D with earlier versions of SR.
Shake harder, the K10d and K20d has the same system and rattle as well. Some might be a little tighter and need a tap to rattle, others only need to be tilted for the sensor to move.
05-29-2016, 12:06 PM   #17
Na Horuk's Avatar
QuoteOriginally posted by Gimbal Quote
Shake harder,
Okay, don't actually shake harder You might ruin something if you shake too hard!
But another thing to consider is that the SR mechanism, while still the same principle, has been updated and upgraded throughout the years.
05-29-2016, 01:56 PM   #18
Try running dust removal and you'll hear it loud and clear
05-30-2016, 06:49 AM   #19
seanix's Avatar
That is not a rattle. That is a high frequency vibration and it's caused by the user manually and intentionally activating the dust removal feature.
The reason that people with older cameras with less advanced SR systems are confused/concerned is because the SR system in the K-1 makes a rattle noise when you gently turn the camera over to change a lens, or when you pull the camera out of your bag, or when it bumps gently against your body when using a neck strap to shoulder sling. With a K20D, no matter how hard you shake it (within reason), it does not make any noise.
The bottom line is that it's nothing to worry about, no matter what Pentax dSLR you have, but newer ones with more advanced SR systems seem to be louder than older ones.
05-30-2016, 08:00 AM   #20
Well it should. Sounds like the sensor is stuck or something. It's the same principle as in the K-1, albeit slightly smaller.
05-30-2016, 03:25 PM   #21
The DR system in the K20D is not ultrasonic, unlike the DR II used in all future flagships. Hence, when activated, it will make a shaking noise similar to what you'd here if you shook the camera really hard yourself. But yes, not the same as the clunk sound that most people hear- just something similar to illustrate the concept.
24x36mm, box, camera, canon, full-frame, k-1, nikon, pentax, rattle, screen, sr
How does the K-1 meter with M lenses? Wolfeye Pentax Full Frame 29 03-11-2016 05:16 AM
How does the Nikon D500 affect the K-1? jatrax Pentax Full Frame 36 01-15-2016 02:28 PM
Does your Pentax-m 50mm/1.4, 50mm/1.7 rattle Hamster Pentax SLR Lens Discussion 8 01-04-2010 12:19 PM
Slight rattle M 50 1.4 jax_zee Pentax SLR Lens Discussion 5 08-01-2009 10:41 AM
Does your K-7 rattle? Nubi Troubleshooting and Beginner Help 9 07-23-2009 02:47 PM
All times are GMT -7. The time now is 05:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
