05-29-2016, 09:36 PM   #16
Otis Memorial Pentaxian
clackers's Avatar
Th
As for legacy glass: Pentax FA* 24/1.8
f2 rather than f1.8?
05-29-2016, 10:03 PM   #17
Yes...f/2 Thanks for the kick!
05-30-2016, 03:43 AM   #18
Ed Hurst's Avatar
Thanks everyone for the input. Very useful!
The usage I have in mind is Milky Way photography making use of the K1's astrotracking capability. I'm aiming for the ability to do it without stitching, or not much anyway, which requires a very wide field of view. Ideally a wide aperture also helps control noise by reducing required ISO, though of course the astrotracking allows longer exposures without trailing (though very low ISOs will remain out of reach, as the function starts to reach its precision limit in exposure duration - so lens speed is still a consideration).
In the end, I can stitch more of course, but would be nice not to have to.
If I want to achieve super high quality, UWA and high speed, it seems the lenses don't yet exist for the K1.
05-30-2016, 04:06 AM   #19
D1N0's Avatar
QuoteOriginally posted by Ed Hurst Quote
Nor for other brands on full frame. There is the Sigma 20mm F1.4 and the Nikon 20mm F1.8 But nothing below 20mm. The Samyang 16mm F2 is an aps-c lens. F2.8 is the brightest you will get in the 14-19mm range (apart from the Irix which is 2.4). Your best bets for astrography would be the yet to be launched Irix or the Samyang 14mm F2.8 which is a steal. (Here's a review: http://www.lonelyspeck.com/rokinon-14mm-f2-8-review/ )
05-30-2016, 04:10 AM   #20
Look into Samyangs wide lenses, they are supposedly very good when it comes to astrophotography.
05-30-2016, 06:08 AM   #21
Ed Hurst's Avatar
QuoteOriginally posted by D1N0 Quote
Nor for other brands on full frame. There is the Sigma 20mm F1.4 and the Nikon 20mm F1.8 But nothing below 20mm. The Samyang 16mm F2 is an aps-c lens. F2.8 is the brightest you will get in the 14-19mm range (apart from the Irix which is 2.4). Your best bets for astrography would be the yet to be launched Irix or the Samyang 14mm F2.8 which is a steal. (Here's a review: Rokinon 14mm f/2.8 IF ED UMC Review – Lonely Speck )
I'd settle for a K1 compatible version of the Nikon 14-24 f2.8 or Tamron 15-30 f2.8 to be honest. Either outperforms the Samyang/Rokinon I believe...? Out to FF corners anyway...
05-30-2016, 06:17 AM   #22
D1N0's Avatar
There is one: HD Pentax-D FA 15-30mm F2.8 ED SDM WR Reviews - D FA Zoom Lenses - Pentax Lens Reviews & Lens Database
05-30-2016, 06:37 AM   #23
Ed Hurst's Avatar
Thanks for that. Had rejected that option for its poor corner performance...
05-30-2016, 06:39 AM   #24
Franc's Avatar
You like the Tamron version but not the Pentax one? Thats weird, its the same lens. The Pentax version is a rebadged Tamron (with better coatings e.d)
---------- Post added 30th May 2016 at 15:58 ----------
there is a Zeiss Distagon 15/2.8 in M42 available. That should fit and work.
05-30-2016, 03:36 PM   #25
Wouldn't the distagon be more susceptible to coma though?
05-30-2016, 03:43 PM   #26
The corners aren't any worse than say the 24-70mm at 70mm. The reason people complain is mainly field curvature. Since the astrotracer will likely soften your corners regardless, I wouldn't consider this to be an issue- plus the lens is extremely sharp otherwise.
That said, overall the Pentax lineup is still missing fast ultra wide prime options, but if you look at Nikon many of theirs were also just added recently.
05-31-2016, 08:22 AM   #27
osv
Tamron 15-30 mm f/2.8 Di VC USD review - Coma, astigmatism and bokeh - LensTip.com
24x36mm, full-frame, k1, options, pentax, tamron, version, wides
Sigma EF-610 DG Super on K1 emsee Pentax Camera and Field Accessories 14 03-12-2017 08:39 AM
The case for a fast super wide Ed Hurst Pentax Medium Format 35 03-02-2016 04:05 PM
DxO and ultra-wides for Pentax... causey Pentax SLR Lens Discussion 10 11-01-2010 08:50 PM
What's the best of these 3 super-wides: Sigma 10-20, Pentax 14, or Pentax 12-24? Grimlock Pentax SLR Lens Discussion 55 07-05-2009 09:01 PM
Best short FAST zoom lens for K100 Super audio_mad Pentax SLR Lens Discussion 3 03-02-2009 12:24 PM
All times are GMT -7. The time now is 09:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
