Originally posted by Ed Hurst , I'd like something in the 14mm to 19mm range, faster than f2.8.
Ultra wide, faster than f2.8, and FF? That is aiming high. Practically doesn't exist. Sigma's 24-35mm f2 is the only lens I can think of, and its not made in K-mount (at least, not yet. Feel free to encourage Sigma to do it). Pentax' DFA 15-30mm f2.8 is the closest that Pentax gets to your criteria, and is reportedly a pretty great lens.
The Sigma 18-35mm f1.8 is not FF; it has heavy vignetting and does not cover the edges on the wider end. It is made for K-mount, though
Samyang 14mm f2.8 is your next best bet. It has A an aperture ring, but no AF. Good lens, sharp, but does not have filter threads. Just make sure you get a good copy, without decentering, and you should be fine. Very affordable, too.
Originally posted by Ed Hurst are actually full frame compatible
All DFA, FA, F and older lenses are FF compatible. Many DA lenses are FF compatible - there are some threads about this already. Feel free to search "DA lenses on FF" or similar keywords. However, with DA lenses, Pentax does not guarantee that the edges will be top quality, or even useable (particularly zoom lenses sometimes fade out to completely black edges on FF, as they only cover ASPC frame)
Sigma has some other designations (DX, DG??), but I don't really know much about those, so double check.
Samyang 14mm, 24mm, 35mm, 50mm, 85mm, 100mm are FF compatible, as far as I know. Samyang 8mm, 10mm, 16mm are not.
