I have been super busy with travel and other things so I have missed out on a lot of the threads about the K1.
Because I am building a kit primarily for travel I am wondering about some size and weight questions.
My current travel kit consists of a K3+battery grip (with batteries) and my go to zoom lens is the 16-85mm (for now). To me the total weight is negligible. I've gotten used to it. Basically though walking through all this will help me visualize and think through any future decisions.
The specs on the the K3 list it as 715g (800g with battery and cards)
The specs on the 16-85mm list it as 488g
The battery grip (with battery) I have no clue what the combined weight is. Nor do I know the total combined weight of what I am carrying is.
Based on some rough math the battery weighs around 80g but I have no idea what the weight is of the grip itself.
So far I am up to 800g+488g+80g (spare battery)+whatever the grip weight is (I am guessing around 300g) (if anyone knows please tell me)
The total I got was somewhere around the 1700g area (or rounding about 3.7lbs)
The K1 is much easier to figure out.
1010g for the camera, battery and cards+ 787g for the 24-70 that I am eyeballing for a total of 1797g (3.96lbs) without the grip. (Basically +1/4 lb)
If I guesstimate the weight of the K1 grip and battery to be about the same as the K3 +- some the total then kicks up to 2177g with the grip. (4.7lb)
Basically more or less I would gain one full pound if I run it the same way using that lens and a grip. If I lose the grip on the K1 it will be about the same as I am used to, just a slight bit heavier but not much which is easily manageable.
In comparison if I carry my Tamron 70-200 on my camera all together that's like 5.1lbs...I've tried that before and boy that was a brick. After a while I wanted to put that thing down. Admittedly part of that wasn't just weight but the length of that lens swaying around...but I can tell you this much... I don't carry that combo very much at all, if ever.
Also though went you consider carry on luggage requirements and all that I am trying to get an idea of what I would be in for on that level as well.
That's part 1... now for part 2.
Next question that I am thinking through... weight wise without the battery grip the K1 with that lens would be more than manageable. Basically adding 1/4 of a pound is not a deal breaker. With the grip though it's a different story.
I went to a site and did camera dimensions comparisons and I see that the K1 is taller... and not just on the top around the viewfinder area. The truth is I have grown accustomed to the battery grip but if the K3 was a smidgin higher where you actually hold the camera I could lose the battery grip and not worry about it. I don't use the battery grip for much other than comfort. With the K3 and no grip my pinky has no where to go. Again it is kind of nice having a spare battery but that's not a big deal at all.
So basically if you measure a K3 from the bottom of front adjustment wheel to the table top and you measure a K1 from the bottom of the front adjustment wheel to the table top how much area do you gain?
Unfortunately I can't just go to the store and pick one up to test so before I haul off and spend $3500 bucks I am trying to get a good idea here. It's a question that could be answered in 5 seconds by picking one up in my own hands, but that's not an option right now.
I know it's some picky stuff but if anyone has some calipers or anything at all it will just answer some lingering questions while I save my pennies.
