06-07-2016, 01:27 PM   #1
Dark focus screen
Need some help from some of you out there. Picked up the K1 to shoot my niece's wedding on Thursday. Does any one else feel like the focus screen is darker than it should be? Any way to brighten it up?
I'm using the 28-105 lens, but I must be doing something wrong. Pictures are way darker than they should be:
Attempt #1: Manual mode: ISO 100, 1/250, f8. Standing outside taking a picture of the house. Have to bump to ISO 400 even to get an image on the screen.
Attempt #2: Tried adjusting EV values --- they work in LiveView but it makes no difference when you actually take the picture. It's like they're being ignored. Tried in both TV and Manual mode
Attempt #3: Set to AUTO. It lowered the shutter speed to 1/25, which blurred everything, and raised the ISO to 800. Again, we're talking high noon outside.
Is it because the sensor is so much bigger than it needs so much more light?
Need some help from other K1 users
Thanks in advance.
Last edited by Brugge4Him; 06-07-2016 at 02:28 PM. Reason: incorrect shutter speed initially listed
06-07-2016, 01:29 PM   #2
bilybianca's Avatar
To me it sounds like there i something wrong with the diaphragm in the lens. Oily, sticky leafs? Aperture lever bent?
Kjell
06-07-2016, 01:50 PM   #3
Paul the Sunman's Avatar
QuoteOriginally posted by Brugge4Him Quote
Attempt #3: Set to AUTO. It lowered the ISO to 1/25, which blurred everything. Again, we're talking high noon outside.
Thanks in advance.
By "focus screen" are you saying it appears dark in the optical viewfinder? And similarly in LV?
Do you have another lens you can try? It sounds like the lens is stopped down. It should be wide open till you take the shot (or activate DoF preview). How does it appear off camera? Fully open?
By the way, what happens if you try DoF preview; does it get darker still?
Is your battery charged? Someone on PF said the OVF is dark when the battery is removed.
06-07-2016, 01:55 PM   #4
QuoteOriginally posted by Paul the Sunman Quote
Dark in the optical viewfinder. The LV is plenty bright. I only have one other lens, a manual 50mm 1:1.2. It looks the same way through the viewfinder. Batteries are charged
---------- Post added 06-07-16 at 12:58 ----------
QuoteOriginally posted by bilybianca Quote
Kjell
Don't think it would be the lens, I just bought it yesterday, it's new. But who knows.
06-07-2016, 02:11 PM   #5
is the lens on all the way, locked in place?
06-07-2016, 02:17 PM   #6
But changing ISO has nothing to do with the OVF! I don't understand what you are saying.
1/25 isn't an ISO, it's a shutter time.
No.
I am very confused by what you are saying.
Specific questions:
  1. With LV off, is the view through the optical viewfinder dark?
  2. With LV turned on, is the rear screen dark, or does it look normal?
  3. What do the pictures look like when you display them on the rear screen or import them to a computer?
By the way, the rear screen brightness on the K1 can be adjusted significantly, to suit indoor, night, and even full sun situations. This is not true of the focussing screen you see through the OVF.
06-07-2016, 02:24 PM   #7
QuoteOriginally posted by sculptor666 Quote
Was hoping that was it, but it's locked on tight. Even tried 2 other lenses.
---------- Post added 06-07-16 at 13:26 ----------
No.
Specific questions:
Sorry, slip of the fingers, on auto, the ISO moved to 400 and the shutter speed was 1/25.
06-07-2016, 03:44 PM   #8
Green mode may yield some results, or at least make it easier to tell if there is a persistent problem.
06-08-2016, 02:57 AM   #9
After you unpacked the camera for the first time, did you peel off the dark plastic film from the sensor?
06-08-2016, 03:15 AM   #10
check the lens just like the other guy suggested the lens diaphragm
06-08-2016, 05:36 AM   #11
pete-tarmigan's Avatar
Didn't someone post a thread a couple of weeks ago on this same topic? If I recall correctly, the consensus was that optical viewfinder goes dim when the camera auto-shuts down, i.e., the LCD overlay in the optical viewfinder turns off, darkening the view. Pressing the shutter release half-way wakes the camera and wakes up the LCD overlay.
06-09-2016, 01:05 AM   #12
Barry Pearson's Avatar
QuoteOriginally posted by pete-tarmigan Quote
What makes the optical viewfinder go dark is taking the battery out.
I think the K-1 draws enough power from the battery even when powered off to keep the LCD normal. Time-out doesn't affect it.
06-09-2016, 02:48 AM   #13
Tan68's Avatar
Bruges, Happyman is making a joke. There is nothing to remove from the sensor surface.
06-09-2016, 02:50 AM   #14
The 28-105mm vignettes a lot. My experience with that lens is consistent with yours- it darkens the viewfinder more than most other lenses I've tried.
06-09-2016, 04:11 AM   #15
I haven't seen any signs of vignetting with that lens! At what focal lengths and what apertures does it vignette?
There were no specific vignetting corrections in the following, and there was no lens profile for it at the time:
Photos using articulated LCD & 28-105mm lens
Photos showing the quality of the 28-105mm lens
I agree that it isn't as bright in the viewfinder as the other new lenses, because of its smaller apertures. But that isn't vignetting, which is all about what happens in the corners.
There was no hint of vignetting in the ePHOTOzine review, although perhaps they didn't test for it.
24x36mm, attempt, battery, dof, focus, full-frame, help, iso, k1, lens, lv, mode, pentax, picture, preview, saying, screen, shutter, viewfinder
Manual Focus: K-01 or Focus Screen? Dean Bradshaw Troubleshooting and Beginner Help 12 03-06-2014 11:14 AM
Focus calibration - who to believe?! (hex or focus screen) heartattackandvine Troubleshooting and Beginner Help 14 12-05-2013 01:34 AM
Focus problems - display screen in focus result blurred Phillean Pentax K-01 9 01-16-2013 04:53 AM
K-x focus screen drawing & Travor focus screen issue xjx Pentax DSLR and Camera Articles 2 06-06-2012 10:13 PM
Quick Question: Pentax KM screen replaceable with split-focus screen? vinzer Pentax Film SLR Discussion 2 01-06-2009 01:21 AM
All times are GMT -7. The time now is 06:37 PM. | See also: NikonForums.com, part of our network of photo forums!
