06-20-2016, 01:17 PM   #1
K-1 locked up twice
I was shooting an event Saturday and it locked up twice. I couldn't do anything ( I had my back up so all was well, I didn't miss anything).. Popped the battery door and turned it back on.. worked fine.. The first time, it appeared to be "on" meaning, I could see all of the info on the screen. The second, it was black. I changed the battery after both occurrences. Any ideas what might have happened? Humidity was high, temperature was in the high 80s.
06-20-2016, 01:27 PM   #2
Low battery / high drain?
06-20-2016, 01:35 PM   #3
The first time when you could see all of the settings, could you change settings/see the changes occurring? Had you just shot quite a few photos leading up to the freeze? I was taken by surprise a few times when I didn't get any response from the shutter, but I quickly realized it was a full buffer, and the orange light was working away for quite some time after. Shooting Raw to two cards on there really loads that buffer up!
I hope that it's nothing serious - had you updated the firmware yet?
06-20-2016, 03:24 PM   #4
Were you using the battery grip?
With my K-3, lock-ups were once or twice triggered by something about the battery grip - either the connection or the battery grip/battery power settings.
06-20-2016, 05:07 PM   #5
I had my first issue a couple of weeks ago. Using Pixel Shift and it appeared to get stuck during the processing stage, the progress bar just stayed there and didn't progress. I left it for a couple of minutes just to be sure. Still in the same spot. So I pulled the battery and turned it back on and all was fine. If I recall correctly I think the processed file had even been saved. I didn't think too much of it and kept on going. No repeat. Will watch for this again.
06-20-2016, 08:11 PM   #6
Format card?
I have read where cameras have locked up if the SD card was not formatted before use.
06-21-2016, 04:20 AM   #7
Edgar_in_Indy's Avatar
I never had a lockup with my K-x, but my K-30 does lock up from time to time, and requires a battery removal. And it seems like other models from the K-30 onward also suffer similar problems.
Not a real big deal, as it only happens only very occasionally, and taking the battery out quickly sorts it out. But still kind of annoying.
06-21-2016, 07:07 AM   #8
QuoteOriginally posted by aikilink Quote
I couldn't release the shutter or change any of the settings. I had shot quite a few images prior to the freeze, but over the course of the day not rapid fire shooting.
---------- Post added 06-21-16 at 07:08 AM ----------
QuoteOriginally posted by Edgar_in_Indy Quote
yes very annoying. All my batteries were fully charged as well. My K-3 did this once or twice before as well now that I think about it.
no battery grip! I have one just didn't have it on at this time.
---------- Post added 06-21-16 at 07:11 AM ----------
At the time, I had not updated firmware. It's on my list of things to do tonight.
06-25-2016, 03:41 PM   #9
Have you formated the SD card with the K-1? Some problems of data transfert may occur when the format is done on computer or if the card come from another camera.
06-25-2016, 04:03 PM   #10
phat_bog's Avatar
happened on K3II a few times (maybe 10) before mainboard died at 8,000 clicks.
never happened on a K3 , but K3 became electronically super buggy and sent to be serviced at 4,000 clicks
more recently on the K-1:
this thing happended to me a few times ( 9? 10? not more) on the interval of today's +20,000 clicks.
with or without the grip. everything else works perfect on it.
so honestly, no clue.
06-25-2016, 09:29 PM   #11
I have no idea if it will help, but the 1.10 firmware update is supposed to have "Improved stability for general performance."
06-27-2016, 05:44 AM   #12
QuoteOriginally posted by Shureeken Quote
My memory cards were both also fresh, formatted (in camera) cards . 32g a piece.. SanDisk Extreme PRO 32GB UHS-I/U3 SDHC
06-27-2016, 11:40 AM   #13
RDP
The only time my K3 locked up was when I was shooting in very hot, humid conditions in the direct sun. I attributed it to overheating. Pulling the battery out and putting it back in fixed it. No problems since (knock on wood...).
06-28-2016, 07:51 AM   #14
QuoteOriginally posted by RDP Quote
that's kind of what I was thinking. I wasn't in direct sun but it was hot and very humid.
---------- Post added 06-28-16 at 07:51 AM ----------
QuoteOriginally posted by dakotapix Quote
I have since updated the firmware so here's hoping!
06-29-2016, 09:14 PM   #15
QuoteOriginally posted by aslewis02 Quote
Good luck!
24x36mm, annoying, battery, buffer, change, firmware, freeze, full-frame, grip, k-3, k-30, pentax, post, settings, shot, shutter, sun, time
pz-1 mirror locked up ronald_durst Film SLRs and Compact Film Cameras 2 10-09-2013 08:33 PM
Locked up K-5...WTH Ex Finn. Pentax K-5 & K-5 II 9 09-15-2013 12:26 PM
K-5 locked up: return or keep? gs18jlll Pentax K-5 & K-5 II 13 12-28-2011 01:41 PM
Z-1/PZ-1 mirror locked up ... frank Film SLRs and Compact Film Cameras 12 06-02-2011 09:13 PM
K-r locked up peter25 Pentax K-r 3 12-03-2010 11:48 PM
All times are GMT -7. The time now is 02:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
