Originally posted by uday029 I thought f-stop was used for both, combination of exposure and DOF. No? Generally in ANY tutorial, they explain the concept of DOF by f-stop. Higher f-stop for more DOF and vice versa. Atleast, that is how I interpreted it by learning photography from a ton of youtube videos. F-stop controls both exposure and DOF. Isn't T-stop the true measure of how much light a lens lets in? So, is some other factor by which you measure DOF? For a non-technical and not too "sciency" photographer like me (most of the beginners are), his explanation completely makes sense. Different sensor sizes create different DOF at a given f-stop. Atleast, it made sense when he told it. May be I am missing something.
How would you measure DOF? Because when ever I asked anyone (even on this forum) about how to get blurred background, the answer was "Use lower f-stop". So for me, as I am learning photography, f-stop became synonymous with DOF. May be every one is then learning photography the wrong way.
Well... aperture, noted as f-stop, is an element of adjusting exposure just as shutter speed is. f-stop as an element of exposure is the same for this lens or that lens. If you mount either a 50/1.8 set at f/5.6 or a 100/2.8 at f/5.6, you will use the same shutter speed to get the same exposure. I do figure you know this :^)
f-stop as a description of depth of field is not always consistent. That 100mm lens will give you a shorter depth of field at f/5.6 compared to the 50mm lens. However, mounting the 100mm lens will also give you a different (tighter) picture of your scene. If you back up until you have the same view with that 100mm lens as you do with the 50mm lens, the depth of field will be pretty much the same... f-stop as a comparison of DOF across different lenses depends on if you try to keep framing the same.
Keeping the framing the same is an element of the equivalence argument when comparing APS-C to FF using different focal lengths on each camera...
I don't think t-stop is another measurement of DOF. DOF is determined by aperture and this is described by f-stop. t-stop affects shutter speed. A lens at f/5.6 with a t-stop of 6.7 will let you use a faster shutter speed for the same exposure than a lens at f/5.6 with a t-stop of 8... maybe I misunderstand t-stop, but I don't think light transmission will affect DOF which is based on aperture, the physical opening.
---------- Post added 07-15-16 at 06:35 PM ----------
Originally posted by uday029 ... So I am not correct in saying that f2.8 lens on FF is not f 2.8 on APSC purely in terms of DOF? Again, I am talking this in terms of how the photography industry is wanting me to believe what a particular f-stop can do - i.e, create beautiful photos with blurred background or have everything in focus. ...
Yes and no. Perhaps some maybe mixed in.
It depends on subject framing.
Will just swap the same lens from APS-C to FF with the same aperture and stand in the same location? FF will have greater depth of field.
Will you swap the lens from APS-C to FF and then take a few steps forward to keep framing the same? APS-C will have greater DOF.
Visit an on-line DOF calculator and use easy focal lengths like 50mm and 75mm (1.5x as crop is 1.5x to FF) and distances f 10 feet for the 50mm and 15 feet for the 75mm. Pick different sensor sizes and see how DOF changes when you take the picture with:
- same lens & same distance [for different framing and] different sensor size
- same lens but different distance for same framing with different sensor size
- same distance but different focal for same framing with different sensor size
