07-21-2016, 10:04 PM   #1
cam_abyss's Avatar
K1 wired shutter release (Phoenix Aion)
From what I've been able to find, pretty much all previous models of APSC pentax cameras have a 2.5mm jack for wired remote release.
I haven't been able to find much about this topic on the K1... everyone just seems to recommend the infrared remote:
1) Does the K1 have the 2.5mm jack for a remote release?
2) Is this jack the mic or the headphone jack?
3) Anyone have experience using the (canon compatible (2.5mm jack)) Phoenix Aion with their K1?
07-21-2016, 10:11 PM   #2
Yes, No, and No.
The compatibility is the same as with other Pentax bodies, though, so if you've used it with an APS-C Pentax you should be good.
07-21-2016, 10:14 PM   #3
cam_abyss's Avatar
Yes, No, and No.
Yea, I'm dumb... I looked around at a 3D image of the camera and saw where the wired remote jack is... under the SD card slots.
07-22-2016, 06:31 AM   #4
QuoteOriginally posted by cam_abyss Quote
Not quite under the SD slots. It's in a very small separate compartment, covered by a soft flap type cover, just below the SD slots cover. Thus, the SD cards do not have to be exposed to use the wired remote port. Hope this helps.
07-22-2016, 06:59 AM   #5
WPRESTO's Avatar
I've used Vello wired releases (K20, K5, K3, and now K1) and found them satisfactory and considerably less expensive than Pentax's own. I also have a couple Vello radio-remote releases that work perfectly. To be safe, I've purchased several and always carry two in the field against the possibility of failure or loss. I still wish Pentax would use a steel or brass shutter button threaded for an old-fashion, old-reliable mechanical cable release. Several "bridge" cameras have this feature, so it is far from unreasonable or unusable on a DSLR.
07-22-2016, 07:06 AM   #6
MJSfoto1956's Avatar
QuoteOriginally posted by WPRESTO Quote
In particular Fuji had been good about this with their bridge cameras from the start.
M
07-22-2016, 08:03 AM   #7
WPRESTO's Avatar
QuoteOriginally posted by MJSfoto1956 Quote
M
Also Sony, at least on their top-of-the-line bridge camera (rx10 mk III).
07-22-2016, 09:12 AM   #8
cam_abyss's Avatar
M
Agreed, I'm coming from Fuji and I love that they have threaded shutter buttons not just on bridge cameras but many of their mirrorless cameras.
24x36mm, aion, full-frame, jack, k1, k1 wired shutter, pentax, phoenix, release, shutter release phoenix
K1 Remote release connector K-amps Pentax K-1 19 04-11-2016 09:29 PM
Pixel Shifts' Impact on the K1 Shutter Release life-span Fenwoodian Pentax K-1 25 03-26-2016 12:47 PM
Wired Remote Shutter Release C_Jones Pentax Camera and Field Accessories 46 02-23-2016 06:30 PM
Wired remote shutter release? clyde Pentax K-5 12 12-20-2015 06:54 PM
Wired shutter release for K5 WizBird Pentax K-5 5 01-10-2013 05:52 PM
All times are GMT -7. The time now is 04:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
