Originally posted by biz-engineer But if you keep the LCD display in the same position during calibration and use, it should work. Did you see any effect on tracking of stars?
That's what I figured as well, and even though I got a slightly different result it wasn't that much better. I still have quite a large variance in precision during a complete 360 degree turn. At some directions it is spot on, at other directions it is slightly behind and yet other directions the compass is way ahead. A little variance is expected but when the error reaches 20 degrees it is way to much. This could happen with the ogps-1 as well but a couple of re-calibrations later one usually could get a really good accuracy.
---------- Post added 08-28-2016 at 09:01 PM ----------
Originally posted by Adam I recommend revolving the camera along one axis at a time, rotating 180 degrees and back in each of the 6 directions.
Yes, that is what I do. I usually rotate the first axis while still mounted on the tripod, then hook it off and do the other two "by hand".
