10-11-2016, 07:35 AM   #31
MJKoski's Avatar
It is impossible to have universal rule how to focus a landscape image (which hyperfocal focusing tries to achieve). There is usually something eye catching in the image worth focusing to. And Magnified Liveview gets you there. If there is nothing to focus on, then maybe the photo is not worth taking? Using Pixel-Shift successfully with landscape photo requires careful focusing to a target, be it a rock or a stick or whatever, to make it pop.
10-11-2016, 09:14 AM   #32
photoptimist's Avatar
QuoteOriginally posted by MJKoski Quote
You are entirely right that there's no universal rule because there's no universal pattern to landscapes.
To me, the best landscapes often have nothing to focus on (or everything to focus on) in that they capture an entire world that one might walk into and explore. Everything in the landscape is equally pin-sharp -- the wild flowers in the foreground, the trees to the left, the stream to the right, the rugged mountains in the background, the brilliant marshmallow clouds on a deep azure sky. They can be a like a natural wheres-Waldo picture with interesting animals, rocks, plants, etc. found throughout the image. But that's me!
Of course, some landscape photos do literally blur into the genres of more specific subject photography (e.g., wildlife, wedding, trains, BIF, etc.) in having a specific focal subject with the surrounding landscape providing a supporting/complementary role.
10-11-2016, 07:01 PM - 1 Like   #33
mee
haha that is why I like looking at large resolution images 1:1 on a smaller resolution screen.. it is like Where's Waldo.
I think TJ Drysdale is one of those photographers that blurs the line.. in his case I think it is between landscape and portraiture. He seems to really use the environment as a blanket, enveloping his subjects. I would post a link to his page but some of his images are sadly a bit nsfw.
10-12-2016, 06:50 AM - 1 Like   #34
Fogel70's Avatar
And sometimes the most interesting landscape photograph is the one where the whole image is blurred, without anything in focus, that looks more like a painting.
FI like some of these...
Steven Friedman Landscape Photography | The Abstract Landscape - Steven Friedman Landscape Photography
10-22-2016, 12:30 AM   #35
Focus method depends on situation. What should be in focus? Can everything desired be in focus at a reasonable aperture? Sometimes setting the hyper focal distance is all that is needed. Sometimes near-focus and far-focus points should be determined to set a mid-point. Magnified live view is the most accurate way to do that.
10-22-2016, 03:53 AM   #36
MJKoski's Avatar
Then there is a big but. Low MP bodies work reasonably fine using the hyperfocal concept. But when you do large print of a picture taken with something like K-1 (and higher res) the outcome will look messy due to nothing really being sharp (unless something hits the real focus point) or diffraction softening with small aperture.
Real solution is to use tilt effectively or focus stacking. That is the only way as MP count just seems to rise for no real reason.
10-22-2016, 04:27 AM   #37
If you don't need high MP you can always donwsample, problem solved.
10-22-2016, 05:27 AM   #38
MJKoski's Avatar
Sure. It still does not remove the cause. Web galleries in general cause wrong impressions of sharpness and make people tend to forget The Big Picture.
10-22-2016, 06:11 AM   #39
Digitalis's Avatar
While this is true when viewing your images at 1:1 pixel level, you're forgetting that in print, the diffraction softening can easily be countered to the point of being imperceptible in a 36X24 inch print. With some subjects Focus stacking can't always be used, and you have to work with just the one shot.
10-22-2016, 06:38 AM   #40
MJKoski's Avatar
Yes there are sharpening methods. They also have their limits before the output starts to look artificial. I refuse to print smaller than 1.25 meters wide when dealing with base ISO images and 36MP is already at its limit here so I have just chosen to stay under diffraction barrier whenever possible.
10-22-2016, 07:00 AM   #41
Digitalis's Avatar
chicken.
10-22-2016, 08:35 AM   #42
MJKoski's Avatar
El Pollo Diablo.
10-22-2016, 10:56 PM   #43
Diffraction barrier is a term used in microscopy to note the limit of resolution in optical systems of about 1/2 wavelength of the light used. How does staying "under diffraction barrier" do anything for your images?
10-23-2016, 12:45 AM   #44
Moderator PEG Judges
Kerrowdown's Avatar
When I start missing focus on a regular basis rather just occasionally... I make an appointment for Specsavers (a retail optician), this usually resolves my issues.
10-23-2016, 04:48 AM   #45
Digitalis's Avatar
QuoteOriginally posted by civiletti Quote
If I had to hazard a guess it would increase accutance at the plane of immediate focus, making the rest of the images look soft by comparison.
24x36mm, focus, focus method, full-frame, landscape, method, method in landscape, pentax, photography
Recommend a lens for landscape/urban landscape photography a96agli Pentax SLR Lens Discussion 23 01-22-2015 10:26 AM
How to take in-focus wide family in front of landscape photos? Newtophotos Photographic Technique 18 10-13-2013 09:08 AM
Kayak Aerial Photography Method with Pentax Q digital029art Pentax Q 13 06-02-2013 03:20 PM
Lens options for landscape photography in Canda CrazyNuts Pentax SLR Lens Discussion 24 07-09-2012 06:49 PM
Method of manual focus Capslock118 Troubleshooting and Beginner Help 10 04-29-2011 06:44 AM
All times are GMT -7. The time now is 09:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
