10-13-2016, 05:35 PM   #1
Memory Cards for K-1
I was doing a shoot recently and noticed that the K-1 buffer would freeze up for a period of time after taking 4-6 shots. I have an SDHC 10 card. Can anyone who has a class leading SD card let me know what kind of buffer I can expect with a better card? Is this a problem with the K-1's buffer itself or is it likely my card?
10-13-2016, 05:59 PM   #2
Tas
QuoteOriginally posted by larsbars Quote
It's hard to say why your buffer is full after 4-6 images.
An obvious thing to start with though is to make sure you've formatted the card in the camera.
I use 2 x 64GB Sandisk Extreme Pro SD XC I cards that are class 10 and rated at 95MB/s. There are tests that identify the K-1 as unable to transfer at that speed. And yes the buffer does get full when you use burst modes, I've run into this problem frequently shooting sporting events.
To try and provide some useful feedback I set my camera in Constant High drive mode and could easily get over 15 images before there was a slow down in the capture rate. The camera would continue firing past this point in each of the four attempts I made and is consistent with my experience when shooting sports. The buffer isn't fast to clear with that many 36 megapixel RAW images, though this wasn't the point of your post. I can confirm for you therefore that the K-1 buffer is not going to be full after 4-6 shots.
It might also help adding some more info on camera settings and the SD card used so other forum members can have better context for posting to this thread.
Tas
10-14-2016, 02:14 AM   #3
D1N0's Avatar
Did you get a reliable brand from a reliable source? There are a lot of fakers out there. You can test the card with software described in this post: https://www.pentaxforums.com/forums/60-accessory-memory-articles/119185-measu...rformance.html
You should have a burst of about 17 raws with a SanDisk Extreme Pro 95MB/s UHS-I SDHC as tested by imaging resource. sdhc class 10 has a minimum writing speed of 10MB/s so there are great differences between cards.
10-14-2016, 02:23 AM - 1 Like   #4
I use only this card:
Amazon.com: Transcend 32 GB High Speed 10 UHS Flash Memory Card (TS32GSDU3X): TRANSCEND: Computers & Accessories
95 MB/s reading and 85 MB/s in writing. It is very fast. The K-1 is not compatible with UHS-II.
10-14-2016, 04:40 AM   #5
what type memory card do you have? it is look like the memory card problem - uncompactibility with K-1. I have/had on K-3, Nikon D750 and K-1 many cards and absolutely no problem (Trandscend 16GB Ultimate 600x SDHC-10 UHS1(1) 90MB/s, Samsung 32GB PRO SDHC-10 UHS1(1) 90MB/s, Sandisk 16GB Extreme PLUS SDHC-10 UHS1(1) 80MB/s, SanDisk 64GB Extreme PRO SDXC-10 UHS1(3) 95MB/s).
Try another brand/type of card.
10-14-2016, 11:06 AM   #6
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Tas Quote
I'm currently using a batch of 32GB versions of the above, so far without dramas, but I don't "spray and pray" so buffer rates are not an issue for me.
Just to reconfirm what D1N0 has already said, watch the source of your cards.
10-14-2016, 12:30 PM   #7
Make sure you're using a UHS-I card with 30 Mb/s+ write speeds for the fastest performance.
If your camera is locking up, it's likely not due to the card (unless it's a really slow card) but rather lens corrections such as distortion correction, which adds a lot of processing time.
See also:
Comprehensive SD Card Guide for Photographers - Articles and Tips | PentaxForums.com
Pentax K-1 Review - Performance and Burst Mode | PentaxForums.com Reviews
10-14-2016, 02:26 PM   #8
Tas
QuoteOriginally posted by Kerrowdown Quote
Are you trying to tell me something? Englishman....
10-15-2016, 02:17 AM   #9
PEG Moderator
Kerrowdown's Avatar
If I were English I might be, but as a Scot... certainly not.
10-15-2016, 01:33 PM   #10
QuoteOriginally posted by juanma_1 Quote
I use only this card: Amazon.com: Transcend 32 GB High Speed 10 UHS Flash Memory Card (TS32GSDU3X): TRANSCEND: Computers & Accessories
Thanks for the tip. The card seems a good price too. I'll give it a try.
10-16-2016, 09:05 AM   #11
Thanks
Thanks for the tips everyone! Glad to hear that it's my card.
24x36mm, buffer, card, full-frame, k-1, memory cards, pentax
K-7 Memory Cards - Largest Size that can be used - Firmware update? Mark 2112 Visitors' Center 3 09-27-2016 12:59 AM
New, Expensive Memory Cards For Pentax Full Frame? Fenwoodian Pentax Full Frame 10 02-03-2016 04:01 PM
Fastest Memory Cards for K3/II evilcartman Pentax K-3 14 08-10-2015 12:26 PM
Case for Memory Cards Belcik Pentax Camera and Field Accessories 5 02-23-2012 10:32 AM
Pentax K-X eats memory cards Frundock Pentax DSLR Discussion 17 11-06-2010 07:55 PM
All times are GMT -7. The time now is 05:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
