11-06-2016, 03:03 PM   #1
Lightroom 6: "Preview Unavailable for this File"
Apologies if this question has already been addressed on the forum.
I recently purchased a K1, and tried to import my first pictures into Lightroom 5.7.
I received the message that the preview is unavailable... "The files are not recognized by the raw format support in Lightroom"
I did a forum search and found that I needed to upgrade to Lightroom 6, which I just did. I upgraded, downloaded, and am using Lightroom 6. However, I'm still getting the same message above.
Also, under Lens Corrections, it's not recognizing any profiles. I'm shooting the K1 + FA77
Would appreciate any help. Thanks
11-06-2016, 03:17 PM   #2
Lightroom 5.7 opens my K1 raw files. I use DNG format. Are you using PEF?
11-06-2016, 03:37 PM   #3
screwdriver222's Avatar
I had no problems with LR5.7 opening files. I recently changed to LR6 just to get the lens ID and profiles for for the new DFAs
Jeff
---------- Post added 11-06-16 at 10:43 PM ----------
Just a quick thought. Are you shooting in Raw. I just had a problem with my last batch of photos where LR showed no Pentax lens profiles were available. After a couple hours including re-installing LR, I checked the camera and it was set to JPEG and that was why.
Jeff
11-06-2016, 06:47 PM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by Antifreez Quote
You might want to re-import the files.
11-06-2016, 09:39 PM   #5
QuoteOriginally posted by red_potatoes Quote
The first round of photos I took was with PEF files. Once I realized I couldn't open them in Lightroom 5.7, I started shooting in DNG. However, even after upgrading to Lightroom 6, I'm not able to view the PEF files.
QuoteOriginally posted by screwdriver222 Quote
[/COLOR]Just a quick thought. Are you shooting in Raw. I just had a problem with my last batch of photos where LR showed no Pentax lens profiles were available. After a couple hours including re-installing LR, I checked the camera and it was set to JPEG and that was why.
Jeff
Ah, thanks. I had converted those PEF files to JPEG to view them in Lightroom. That's why the profile info wasn't coming up. I just checked on the DNG files and I'm seeing the profiles.
Any other ideas as to why I can't view the PEF files in Lightroom 6 would be great. I'll plan to call Adobe/Lightroom for support when I get a chance.
11-06-2016, 09:48 PM   #6
RollsUp's Avatar
Do you have latest version of LR6 installed?
11-06-2016, 09:58 PM   #7
Does LR6 continue to get camera raw profile updates? I though only LR CC was getting those updates now?
11-06-2016, 09:59 PM   #8
QuoteOriginally posted by RollsUp Quote
That's a good question. I just paid for the upgrade to LR6 today. I uploaded the software and assumed I would now have the latest version, which I believe is 6.7? Can you tell me how to confirm that?
11-06-2016, 10:02 PM   #9
That's the latest version, CC notwithstanding.
11-06-2016, 10:02 PM   #10
QuoteOriginally posted by lithedreamer Quote
I decided to get the LR6 software rather than do the CC membership. I knew with that choice that I wouldn't get the periodic updates, but it was my understanding that LR6 would be able to read the K1 PEF raw files.
11-06-2016, 10:09 PM   #11
Ah, you're right. Support for the K-1 was added in 6.5.1. Even D FA lenses are supported through 6.7 with lens corrections, FYI.
11-06-2016, 11:01 PM   #12
I've discovered another strange issue as I've started using LR6 with my K1 DNG files.
After importing, I click on an image to Develop. I can see the image as it's buffering, and then once it has completed buffering, it then suddenly loses a significant amount of color. Any ideas as to what is causing this?
11-07-2016, 12:18 AM   #13
Sounds like a graphics card or GPU issue. Does the problem go away if you turn off using the graphics processor, and then re-start LR:
Menu > Edit > Preferences > Performance > Camera Raw: Use Graphics Processor - On|Off
And it might be a good time to check if your [Nvidia/ATI/Intel etc] graphics card is using the latest drivers too.
11-07-2016, 12:47 AM   #14
RollsUp's Avatar
Lightroom Help menu > System Info... will show which version LR you have.
See here for an explanation.
11-07-2016, 01:42 AM   #15
LR 6 when downloaded is version 6.0 all you have to do is update it, click on "help" then "update".
Jeff
24x36mm, forum, full-frame, jeff, k1, lens, lightroom, lr, message, pentax, profiles
over-"exposure" of LCD preview Sluggo Pentax K-01 12 09-03-2016 02:51 PM
How to batch move photos in lightroom from folder "old" to "new"? raider Digital Processing, Software, and Printing 4 07-24-2016 07:54 AM
Program K-50 Green Button for Preview "Test Shot"? Uncle Jaque Pentax DSLR Discussion 4 04-06-2016 10:55 AM
Adobe Lightroom "There is a problem with the video file" Belcik Digital Processing, Software, and Printing 2 07-27-2015 09:23 AM
File this one under "unclear on the concept" gabriel_bc Pentax SLR Lens Discussion 6 04-14-2011 08:37 PM
All times are GMT -7. The time now is 07:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
