Originally posted by stemked I want to maintain 1:1 focus. Frankly I like the waterproof function and if I can get full frame with the 100 DA W, option 1 or 2 above would be my first choice.
You misunderstand some things.
a) You have K-1, that is an FF camera. No lenses will be "cropped" on it. The only problem is if you take a "crop only" lens, then you get dark edges. Pentax only made some crop only lenses, and all of them are marked as DA. Note that
some DA lenses are not crop-only. There are numerous threads and forum articles about this.
b) Focal length is a lens property. IF you get the DA 50mm f1.8 and DFA 50mm f2.8 macro, they will both have the same field of view on your camera. But the DA might have slightly more vignetting, less sharp corners. Field of view is a different thing, which is the focal length and also the sensor size. APSC cameras therefore appear to have higher magnification and longer focal length. But that is only because the edges get cut off.
c) The current lineup of Pentax DFA macro lenses are full frame and go to 1:1 magnification on full frame. The DA 35mm f2.8 limited is not full frame at all focus distances, but is acceptable for some users at some focus distances. I can easily recommend DFA 100mm WR, or one of the older Pentax 100mm f2.8 macro lenses (F, FA, DFA). Practically the same optics, just different features and body.
d) I would recommend you contact a local repair shop. They usually tell you how much it costs to repair before they start repairing.
e) Your other options are Sigma 105mm, Tamron 90mm, Samyang 100mm, Pentax DFA 50mm f2.8, and older lenses. I think the Pentax DFA 100mm WR is pretty great and is among the best AF macro lenses available on the market now
f) WR is not
waterproof.WR is Weather Resistant. Big difference! WR is great, but you cannot go swimming with it. It is only to resist fog, rain and things like that.
