Originally posted by veraikon Ray, the Carl Zeiss Distagon 25/2.8 for Contax/Yashica is an "older" construction (late 70ies ). The construction was also used with the Distagon 25/2.8 for ZF/ZE/ZK The recent ZF/ZE Distagon 25/2.0 is more modern (11 lenses 10 groups, aspherical lens, special glases (higher dispersion), FLE (floating lens elements) design. The Contax C/Y MM you can modify with an Leitax mount for the K1 . At the ZF/ZE it isnīt possible (as far as I know). An maybe alternative ist the ZS (M42) mount (industrial lens) and a K-adaptor
Please write to your local Carl Zeiss centre that you want this Distagon 25/2.0 in PK mount They will answer you only blabla, but hope dies last ...
veraikon, thanks for the reply and information. After contacting David @ Leitax, I decided to get the ZF version of the 25/2.8 lens. The lens and adapter are " in the mail ". There is available a Distagon 25/2.8 ZK available on Ebay @ $920. While I realize that it would be a direct fit, I will have half of that invested. I am currently testing the Contax Vario-Sonnar 35-70 lens with a Leitax mount. Hope to be able to post results here from both lenses soon, likely in the lens club section. Yes, it would be great to have direct fit lenses, hopefully Pentax will fill the void. In the mean time we will use what is available with this great tool ( K1 ). K5, K3, K1, 645D, and 645Z. All that and I will grab the K1 first
Go figure! Thanks again for the reply
Ray
