Originally posted by civiletti Not everything, just this, which makes no sense to me at this point.
The biggest factor in most images for IQ is the quality of the raw file.
In my experience, if I don't see the quality I want in the raw it's not going to be in the finall file, or print.
Can you use post processing to duplicate that? I guess if you're a painter type person, you can create anything from scratch, you don't even need a raw file, just a Photoshop canvas.
But since you say you can do it... how do you create an image like this by blurring an image? It isn't blurry. It's sharp at the pixel level. The dreaminess is something else.
There are occasions, like this one , where I just reach for this lens, because it's going to give me something others don't. It's not the sharpest, but I'll take sharper lenses, like the Tamron 17-50 or DA 18-135 off the camera because of the way the 21 ltd renders it's images.
DA 21 ltd.
The 18-135 at 24mm
The 18-135 is sharper, the 21 td is better, for this type of image. I always take the 18-135 off for the 21 in it's range. I don't believe you can evaluate lenses from test chart comparisons. I believe you have to use the lens and understand it's qualities.
From what I've seen the 31 and 77 would be the same.
Darn, sucked in again.
