I understand your pain with the loss of the flash. For those that just want a one camera lifestyle solution for a diverse range of use, the K-1 lacks in some key areas. In my own case I want to use/take the K-1 but K3 it is from time to time (flash and frame rate mostly, at expense of low light and field of view). it appears that there will be comprimises for some time still.
---------- Post added 29-01-17 at 12:25 PM ----------
Originally posted by Rondec I think Pentax could solve this problem by having a really small external flash that is usable as an off flash controller.
Won't solve it for me, or the OP I think.
There are several circumstances in my own case that I used the OBF and would never have used a seperate flash, no matter what the size. Mostly overseas travel or hiking with a camera and a lens or two.... I might just grab a few personal shots .... can't do that now so easily..... the other use was birding.... Safari Flash extender helped.... I can't bush walk with a flash hanging off the camera.... would be broken in no time.
