Show Printable Version 17 Likes Search this Thread
03-08-2017, 03:56 PM - 1 Like   #16
QuoteOriginally posted by jrpower10 Quote
I think you need a 645z.
. . . with a motorized equatorial mount.
03-08-2017, 04:25 PM - 1 Like   #17
QuoteOriginally posted by mag07 Quote
K1 is heavy. It's brilliant but heavy
It definitely weighs more! However to get used to that all I did was pick it up everyday and do a few shots....When I picked up the K50 it felt LIGHT, like a toy!
K1 gets heavier depending on the lens....its pretty nice street shooting with a DA 40/50....but long telephotoing with the 135-400 I feel the weight.
OP, it may be a time to wait and see....a K3(iii) may be around the corner.Your lens line up shouldn't need much more if you get impatient and go with a K1( some of the DAs you have that you haven't mentioned may do ok @ FF....most work with 1;1 and all work in crop.
03-09-2017, 01:16 AM   #18
QuoteOriginally posted by TER-OR Quote
A sling strap makes a big difference, it distributes the load more comfortably than a neck strap. Not germane to the original post, of course...
It most certainly does. I use a Peak Design strap, cross body, that said, it does not help the weight of all the gear when in a bag/backpack even with a well supported one, after few hours I do start to feel the weight. Not so young anymore haha and trouble with FF, some lenses are much heavier, too. But again, the IQ is worth the effort for me.
03-12-2017, 11:14 AM - 1 Like   #19
I think that for long tele lenses the gain in reach for an APS-C body equals the gain in noise for a FF camera. You can use a 2.8/200 on APS-C to get the same coverage that a 4/300 will bring in FF. For shorter lenses you can get lense with same aperture and coverage, here FF may excel.
03-15-2017, 05:19 AM - 1 Like   #20
Ok, I've taken my time to carefully think about this for a week and I've also read all your great insights here in this thread.
Im definitely looking for what you could call a "miracle" which doesn't exist. I live in Sweden where its very dark most of the year and I like to do some wildlife shooting at dusk and dawn when the light isn't very ideal. I do everything in my power to keep the ISO down as low as possible, I usually shoot moose and dear with my 150-450 at 450mm with a slow shutter speed around 1/40s. I usually have the camera on a tripod and use a wireless remote to shoot fast bursts at my subject. Usually I get 1-2 images that are sharp enough out of 20 shots. This is only if the subject stays perfectly still. With this approach I often hit ISOs around 1600-3200 but sometimes 6400. Thats why I would like a high ISO beast so I could use some faster shutter speeds and bump the ISO a bit more without too much penalty in IQ.
But I guess the K1 isn't what Im looking for. Its better but probably not good enough to justify the price and also the lesser reach it would give me would also push me to crop even more.
I think I will procrastinate for a bit and work with what I have. I might have to learn to use flash for wildlife too.
I have to admit Im a bit of a lazy editor when it comes to noise, I will also try to improve my skills in noise reduction and check out DXOs tool as someone mentioned here.
Thank you all!
I submitted some attachments if anyones interested to check out som sample shots of what I do with my K3.
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
03-15-2017, 06:33 AM   #21
TER-OR's Avatar
I was going to suggest a monopod, but if you're using that nice gimbal head on a tripod you're well ahead of that game.
Maybe the better noise handling of FF would pay off in lower light, as long as you don't crop too heavily. It may be worth looking at Topaz or some other plugin for Photoshop or Lightroom to help with noise. It's definitely pretty technical photography, and quite challenging.
Some say the 16MP Sony sensor in K5 handled dark conditions better than the 24MP in K3. Others argued that if you crop to the same size that difference disappeared.
So there you go, no answer from me! I'll stay in the sun taking pictures of insects and getting more skin cancer.
03-15-2017, 07:06 AM   #22
UncleVanya's Avatar
I thought the method of leveling the noise playing field was downsampling to 16MP. However there is a lot of controversy about this method. Many say it is very crude compared to using dedicated noise reduction which will target noise and attempt to leave detail in a more intelligent way than simple downsizing does.
I personally like DXO Optics prime noise reduction.
03-19-2017, 04:07 AM   #23
Please note it is downsize not crop. The image looks identical, ie, the composition doesn't change but the resolution is downsized to 16 Mpx. A crop changes the composition as you are cutting off bits of the image.
03-21-2017, 06:54 AM - 1 Like   #24
Well here's a quick test at ISO 51200 - both shot with 28-105, hand held. Photos are the original RAW exported as JPEGs in Lightroom. Notice the difference in exposure although both were shot in Av mode under the same conditions. My lens was zoomed to different focal lengths to compensate for the crop factor of the KP. What do you think? First KP, second one K1.
PENTAX KP  Photo
PENTAX K-1  Photo
03-24-2017, 04:26 AM   #25
QuoteOriginally posted by sibyrnes Quote
Wow, thats interesting! The KP image looks a tad bit better than the K1 image, I think. The K1 image is softer and lacks a little more in the fine details.
Did you have any in-camera noisereduction on any of them?
Maybe the KP is a lowlight beast after all.
03-24-2017, 04:57 AM - 1 Like   #26
QuoteOriginally posted by A.Styrlander Quote
I agree. I was surprised and really did not want to believe it - the KP image looks better to me! Those photos were taken with no noise reduction or processing of any kind.
03-24-2017, 06:13 AM   #27
Stavri's Avatar
I don't know if I'd consider the KP images sharper, It seem to be a bit "punchier" with harsher transitions of greys (in the shadow). The K1 has higher Dynamic Range to me. I would try the shoot both cameras underexposed and see how much detail you could recover before image degradation
03-26-2017, 02:48 AM   #28
Focal length and shutter speed are different (even accounting for crop sensor differences). Shutter speed is mean to affect image quality in low light, isn't it?
03-26-2017, 08:19 AM   #29
Please explain how a difference in exposure of .003 sec affects image quality in low light.
03-27-2017, 01:31 PM   #30
This isn't really a proper comparison. You shouldn't compensate for the crop factor by adjusting the zoom. You should have taken each image at the same focal length but moved closer with the K-1 to compensate for the crop factor. This is a better real world comparison of the benefits of one over the other.
24x36mm, aps-c, camera, full-frame, gear, im, isos, k1, k1 or kp, k3, kp, lenses, pentax, system
Why Pentax KP? Para que la Pentax KP? ZeaFoto Pentax KP 16 06-14-2018 08:53 AM
More test images from the Pentax KP compare with D500/K1 melander Pentax KP 3 02-02-2017 11:00 PM
Help me settle a dispute between me and my gf r0ckstarr Digital Processing, Software, and Printing 31 12-16-2015 10:11 PM
Another "Help me decide between K-5, K-30" thread ChooseAName Pentax DSLR Discussion 12 10-15-2012 05:53 PM
help me decide between a 67 and a 645n zosxavius Pentax Medium Format 26 10-14-2012 12:27 PM
All times are GMT -7. The time now is 06:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
