03-11-2017, 06:52 PM   #16
QuoteOriginally posted by TwoUptons Quote
I still shoot in crop mode occasionally, but if I really want the improved IQ I get from the whole sensor, it's disappointing...
But if I don't need the resolution, it's a quick way to crop photos before they get to the computer, and it feels like a bit of extra telephoto...
-Eric
Thanks for your opinion/information Eric.
03-12-2017, 10:53 AM   #17
Honestly, I think you should fo FF on a FF camera - otherwise get a hold of any FF camera with crop mode to get a feeling for it. At the end of the day you want the whole visible image and will ask for more reach in focal length rather than cropping. The real question is here is whether 24-70 or 28-105 is right for you.
03-12-2017, 12:56 PM   #18
QuoteOriginally posted by zapp Quote
I know I would really want the 24 width instead of the 28 on the short end, and do want a zoom as opposed to a prime.
Thanks for your input.
03-12-2017, 06:17 PM   #19
I've done this because I didn't have an appropriate focal length zoom for my application (shooting a performance), and also because the increased frame rate of the APS-C mode was needed.
05-05-2017, 05:30 PM   #20
Why are you guys trying to get this guy to buy a new lens ? He made a good point, why not use the 24-70 in cropped mode to get longer reach, I don't see why not. The question is picture quality. So instead of trying to get this guy to buy a new expensive lens take out your K-1 if you have one slap on the 24-70 if you have one and then set the camera to "CROP" mode. Then take pictures of your cat, or your car and give this guy an honest answer.
05-05-2017, 11:57 PM - 1 Like   #21
pschlute's Avatar
QuoteOriginally posted by hjoseph7 Quote
It depends on your definition of "reach". Using the lens in crop mode does not change the image size in the viewfinder or the image size that the lens produces on the sensor. In the actual picture the camera produces the image is larger, giving the appearance of longer reach. But the only reason it is larger is because a aps-c sized section of the sensor (15mp) was used. This is the same as taking a FF picture of the same subject and cropping it in PP. Both methods would produce an identical image in terms of size and resolution.
The only way to achieve longer "reach" that does not result in an image having reduced resolution is to use a longer lens.
24x36mm, camera, crop, crop mode, equivalent, ff, frame, full-frame, image, k-1, k-3ii, k-5iis, mode, mp, pentax, quality, range, resolution, setup
FF mode - DA15 - crop factors & crop sizes acoufap Pentax K-1 21 05-10-2018 09:49 PM
To crop or not to crop... wildman Pentax Mirrorless Cameras 8 10-17-2016 09:48 AM
IQ comparison between Crop mode & FF mode MyTZuS Pentax K-1 31 10-08-2016 08:26 PM
People To crop or not to crop ZoeB Photo Critique 5 08-05-2015 05:54 AM
All times are GMT -7. The time now is 12:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
