Originally posted by leekil Using it that way, you would be doing the same thing as taking the picture in un-cropped mode and then cropping the photo afterward in order to "zoom in" to make the subject fill more of the frame. If you set the camera to crop mode, then it would basically be doing this for you. But if you are using a full-frame camera you probably want to take advantage of the higher resolution (or wider view) of the full frame, and if you only use it in crop mode, you are not getting those advantages.
So I would be getting the 15 mp version of a cropped image in crop mode. As you said, like a zoom but with less resolution than using the full frame capability (36 mp).
Thank you for the clear definition.
---------- Post added 03-10-17 at 03:50 PM ----------
I will probably plan on getting the K-1 and 24-70 for the best resolution I can get using a zoom, aside from possibly the 645 series. The K-1 has excellent ratings.
