Show Printable Version 4 Likes Search this Thread
04-03-2017, 08:43 PM   #1
Ric's Avatar
Poor JPEG quality
I just read the K-1 review posted here on PF. The reviewer I thought gave it quite high marks even on things that other reviewers tend to downgrade like AF and video. What I thought was very interesting in the conclusion under cons was Poor JPEG quality. Now I've heard some reviewers say the JPEGS were okay, not that great, some like them and said the JPEG's were fine. For those of you who own a K-1 or are familiar with it (unlike me) what is your experience of the JPEG quality on the K-1. I hope to get one someday. At present I have a K-5. Most if not all the time I shoot RAW and convert to JPEG so it should not be a big deal right? Still it would be good to know you can get decent JPEGS if needed. I'd be so grateful for anyone's take on this.
04-03-2017, 08:54 PM   #2
Sandy Hancock's Avatar
I always shoot RAW, so the quality of the in-camera JPEG engine is irrelevant to me. So yes, for the way you shoot I wouldn't worry.
That said, I think it's a bit rich to call the K-1 JPEGs poor - it's just that Fuji (among others?) do them better.
04-03-2017, 09:02 PM   #3
SpecialK's Avatar
QuoteOriginally posted by Ric Quote
If you are a raw shooter you should be unconcerned with camera jpg quality which is no doubt fine, anyway. Perhaps the reviewer did not know how to maximize the settings.
04-03-2017, 09:32 PM - 2 Likes   #4
Ole
Ole's Avatar
The K-1 JPG engine tends to remove fine detail which is evident if you compare the JPG image to the same image developed from RAW. It is not any worse than the JPG engine in the K-5, though, so if you're happy with JPGs from the K-5 you'll be happy with the K-1, too. When we reviewed the K-1 we just found it disappointing that the JPG engine wasn't better than it is considering how great a camera the K-1 is in other aspects. That said, as SpecialK hints at, if you fiddle around with the sharpness and contrast options on the K-1 you may be able to improve matters some.
We're currently reviewing the KP and from what we have seen so far it would appear that the JPG engine is superior to all previous Pentax DSLRs to such degree that shooting JPG rather than RAW could be an option for all but the most critical work.
04-03-2017, 09:46 PM   #5
It depends on your taste, but the factory default settings are poor. If you play with the setting you can get very good results. You definitely have to spend more time adjusting the factory settings, but yes you can get good results. Hopefully Ricoh improves the JPEG engine with a firmware upgrade.
04-03-2017, 10:05 PM   #6
The issue with the Pentax JPEG engine is that it unnecessarily smears details, especially when noise reduction is involved. Color accuracy is also debatable, but IMO a lesser issue.
The former has been improved greatly in the KP and K-70, which use the new "image accelerator" chip to apply more complex processing. JPEG files from those two cameras are close to being as clean as K-1 JPEGs as far as noise goes. I'm not sure if those improvements can be applied retroactively without better hardware.
04-04-2017, 02:38 AM   #7
D1N0's Avatar
Some people recommend tweaking the sharpness settings by turning it to "extra sharpness" small radius sharpening. Then tweak it with the +/- bar. Also turn NR off. (this only works in extra sharpness not on the other sharpness modes which also have a larger sharpness radius). You can find under in the color settings button on the four way controller on the back.
04-04-2017, 03:40 AM   #8
raw+jpg is my preferred, very happy with the resulting jpgs, and so customisable too
04-11-2017, 02:50 PM - 1 Like   #9
C57
[ATTACH]351809[/ATTACH I have a K3 which I have used for a number of trips and for birding so want sharp pic. Have used the K1 now for over a month and see no diference in jpeg sharpness. I have a pentax ful frame 70 - 200 lens do find it sharper than DA lenses on the proper setting. Perhaps that is the difference. Your software program also makes a difference. I attached a photo taken with jpeg and 70 - 200 lens.
PENTAX K-1  Photo
04-11-2017, 02:55 PM   #10
Man With A Camera
Racer X 69's Avatar
Location: The Great Pacific Northwet, in the Land Between Canada and Mexico
QuoteOriginally posted by C57 Quote
Nice photo. Very sharp too.
Oh, and welcome to the clubhouse!
04-12-2017, 02:59 AM   #11
microlight's Avatar
Welcome. Another RAW shooter here, so I'm not concerned about my JPG engine. I save RAW to both cards in case of card failure; it would be easy enough to create a JPG in-camera should I need one, although on the occasions I've processed in-camera, it was to TIFF.
04-12-2017, 08:27 AM   #12
I don't understand the complaint about JPEG quality. There seems to be enough adjustments and options in the K1 to make the JPEGs look anyway you want. I only shoot RAW and it seems to me that anyone really concerned about image quality should do the same.
C57, that is a nice photo but you know if you shot it in RAW you would be able to recover some of the detail lost in the shadows - just sayin'
04-12-2017, 08:44 AM - 1 Like   #13
Otis Memorial Pentaxian
I have heard rumors of a firmware upgrade that will include Canon JPEG emulation as a custom image type. Promised attributes are colors not found in nature, contrast that will wow your friends and built-in ruddy glow and smoothing for Caucasian skin tones.
(...just kidding...)
04-18-2017, 12:15 PM   #14
Ric
Ric's Avatar
Thanks for the informative replies. Appreciate your input as always.
04-19-2017, 03:57 PM   #15
eaglem's Avatar
I shoot in jpeg only and find nothing wrong with the way the Pentax K-1 produces the shots. Images are sharp and colour is true to nature. No jpeg complaints from me.
24x36mm, full-frame, jpeg, jpeg poor quality k-1, jpegs, k-1, pentax, quality, reviewers
Poor, poor Florida jeffkrol General Talk 8 04-01-2011 01:32 PM
Poor poor Huckabee jogiba General Talk 16 03-05-2011 09:16 AM
K-5 Poor quality of embedded JPEG boardhead Pentax K-5 & K-5 II 17 11-11-2010 07:32 AM
Poor, poor Rand Paul jeffkrol General Talk 18 10-19-2010 01:57 PM
RAW + JPEG with JPEG on One Star quality laissezfaire Pentax DSLR Discussion 58 12-10-2008 02:42 PM
All times are GMT -7. The time now is 11:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
