Originally posted by stevebrot Your FA* 400 is internal focus, which may be the source of the problem. Does it still vignette when set to infinity when used with the tubes? Which other lenses have you tried?
Thanks for your reply, as a result I checked one of my much older lenses the smc M 50mm f2 and it works just fine so at least I can get the closeups.
The reason I liked the 400mm with the tubes is I could get the same closeups but with the camera 3 meteres from the subject. A real bonus when shooting insects and other wild life. I did try the 400mm at infinity and it didn't make any difference. The other lenses I tried that were vignetting seem to be ok now so I'm guessing there was a contact issue. However the FA* 400mm still has very dark corners at any setting including infinifty and at any f-stop.
The other lenses that are working (now) are smc A 70-210 f4 (Zoomed to 210) and an FA 28-105 f3.2-4.5 which is also an IF lens.
When I was shooting film I used my MZ-3 and the 400 lens often and got very good results, I also used the combination on my K5, at that time I had a set of kenko auto extension tubes, unfortunately I lost them when I was shooting in a swamp. When I got the Vivitar tubes they didn't initially work on my K5 but someone on the forum had noted this issue and said that if the mounts on the tubes are painted, which they were, it wouldn't work so I sanded the ends to get bare metal and that resolved the problem on the K5.
So I'm still looking for a solution for fa* 400mm lens tube combination but at least I can do the closeup work with the other lenses.
Thanks for your help, you could be right about the Internal Focus on thsi lens.
Garry
