Originally posted by normhead A K-3ii is roughly the same as a 7DmkII. The K-3 has more MP in the sensor, a 20% slower FPS rate and there are many other differences, where one exceeds the other in this or that spec. The Canon probably has better AF for moving objects.
However a K-3ii is about $600 cheaper. You can almost buy a K-1 for the cost of a 7D MKii
7D Mark II uses the old Canon sensor. It has a very good af (far better than K-3 II) and has also a slightly better fps. Build quality is on par on both cameras. If image quality is important, then in my opinion
is far better on K-3 II at any ISO. I would probably choose a 80D instead of a 7D Mark II if I have to choose a Canon crop camera. It's not as fast, but has a good af, decent fps and the sensor is far better than the one from 7D Mark II.
If I have to pick a crop camera from Pentax, I would probably wait the K3 Mark III. It may take another 6-8 months until we can see it, but it will probably worth the wait. K-3 II is a very good camera,
especially for its current price point. I wouldn't buy 7D Mark II if image quality is the first priority.
---------- Post added 09-12-17 at 12:37 PM ----------
How is the Canon lens better? The Pentax has more range, looks just as good on it's charts.
Looking at the charts...
The DA* is about the same as the Canon it's graph looks about the same, ibut the Canon lacks the nice tight construction that SR brings, and is WR. In this case the Pentax is a much better value than the Canon for about the same image quality. Unless you have some examples showing what you are tailing about, I'm just going to dismiss this point outright. Being a 60-250 owner, Pentax has the best lens for less money. I find it kind of outrageous that you'd even say such a thing. Maybe you should in the future specify which lenses you are talking about, because if I can look at one pair of lenses and show you to be wrong (one I actually own), I'm guessing a lot of other folks can too.
To me, Canon would be an inferior lens at a higher price for less capability. How does that make Pentax inferior? Let's not get stupid here.
There are a few things that you missed in your comparation.
1. Pentax 60-250mm weights 1230g (hood and tripod foot included), while Canon 70-200mm F4l IS (stabilised version) weights 915g (hood and tripod foot included). It's a
315g difference in the favor of the Canon lens.
2. Pentax 60-250mm costs 1297$ at B&H, while Canon 70-200mm F4l IS (stabilised version) costs 1099$. It's a
198$ difference in the favor of the Canon lens.
3. I know Pentax has weather sealing, but also Canon 70-200mm f4L IS has (I own one).
4. Pentax 60-250mm has very good image quality, but it is slow to focus, has problems with SDM motor, and has some focus breathing (most of the users, myself included has found out that it is actualy a 230mm at its maximum focal lenght)
5. Pentax 60-250mm has:
- Dimensions (DxL) Approx. 3.2 x 6.6" (8.13 x 16.76 cm)
while Canon 70-200mm has
- Dimensions (DxL) Approx. 3.0 x 6.8" (7.62 x 17.27 cm)
Canon has internal zooming which for some is better, for others is not and others don't care.
6. Canon 70-200mm is fully compatible with full frame cameras, Pentax 60-250mm has some vigneting on K1 (not something to be worry about, but it is visible)
So, although Pentax 60-250mm is good optically, I have to disagree with you regarding some of your conclusions. Pentax 60-250mm is heavier and more expensive than Canon 70-200mm.
