Originally posted by motorhead9999 Hey everyone. First post here, and was looking for some advice. I'm strictly a hobbyist at this point.
If I do a full switch to Pentax, it'll certainly cost me money, but I can mitigate most of the switchover by selling my Canon mount lenses and body. So to quote The Clash...should I stay or should I go?
TIA!
go.
Actually it is as easy as:
Go and get a Pentax.
(if you dont like to do video with your DSLR!!! - the videos from Pentax never come as smooth as the ones you do with canon gear... that may have something to do with the codec or compression or dunno what; IMHO its visible even if the videos are taken with the same framerate.)
There actually is no problem with lenses, (except that AF drive on most lenses is really slow compared to other makers)... There is so much "legacy" glass available.
And most of that legacy glass, is actually pretty good. (I would only tend to suggest a hobbyist, to buy newer lenses if he needs wide angle glass... That has a technical background.)
There is all that F and FA glass thats pretty good, you even can choose from loads of pretty up to date Sigma glass. From time to time Sigma still releases a new lens for the Pentax mount. ... the 35mm 1.4 Art lens for instance is available for PK-Mount.
you may want a bit till October is over. Maybe you will see a new APS-C Pentax body arriving that fits your needs.
If you dont want to wait, just pick up a K-70...(along with an 18-50 DC WR and a 55-300 WR PLM lens)
Its a real nice camera and those 2 lenses i mentioned dont have fast aperture stops in their pockets for you, but they are focusing pretty fast.(I guess
nearly as good as Canon glass) some dealers still may do promotion, then you maybe could pickup a DA 50mm 1.8 for free if you buy the camera new.
And as said before, the 35mm DG Art from Sigma ... you will also get that with a pentax mount.
But if you feel that your compositions are better with FF:
You may want to grab a K-1.
it shoots much faster in crop mode than in FF... (4.5fps - ff and 6.5fps APS-C mode)
The K-1 may not be the blockbuster that it could have been....(They could have charged 2800 for the K-1 and made it
nearly the same specs as the D850(4k video, 7fps bursts in FF, it would have been the same demand, if not much much more i guess.)
... but honestly, i am pretty sure the K-1 beats the Canon 6D Mark II in nearly every way.
---------- Post added 09-10-17 at 10:35 AM ----------
BTW. My part thinks, that Wildlife in pentaxland is actually owned by Sigma ... The 50-500 DG OS HSM or the 150-500 DG OS HSM both do a very good job, none of them has actual weather sealing but you will be good with a coat and by popping a rubber-band over the mounting gap when the lens is already mounted.
AF speed in the sigma is a bit better than in the Pentax DFA 150-450. At least according to what i remember(from using the DFA 150-450).(correct me if I am wrong)
and I feel the OS in the SIGMA is doing a much better job on the tele-end than the Body internal SR from Pentax.(no correction needed ... at least for me it works way better and the feeling when framing is a whole other thing with lens-internal OS on tele-lenses.
Despite that PENTAX cameras offer body internal "Shake Reduction", you really will miss that canon "IS" stabilizer when shooting tele on a PENTAX at first (only if you ever rented a 100-400 that incorporated it)its hardly noticable at 300mm, but much more at 400mm and therefore i would suggest you, that you better keep your eye on buying a 50-500 or 150-500 from SIGMA with HSM and OS if you plan on buying a
good tele-zoom.
keep in mind that you maybe have to switch off SR before using a stabilized lens on a PENTAX body.
otherwise the SR may counteract to what the OS does.
unfortunately lens-stabilizer and body-internal SR dont talk to each other on pentax systems, like they would do on some M43 bodies.
