Originally posted by mcgregni The V6II only offers 2nd Curtain Sync with the X-TTL firmware, and this requires a P-TTL (Pentax dedicated system) flash type, or a Cactus RF60/x. There is 2nd curtain available in both TTL and M modes .....however there is no "cross-brand" compatibility, so Nikon flashes are not supported.
v6ii in that troubleshooting thread has 2nd curtain in ttl and manual – people use it and describe their tests there.
no cross-brand on cactus’ own environment sounds fake, even yongnuo doesn’t care if you use their canon remote to fire a nikon trigger long as they’re both in the 602 or 603 series.
---------- Post added 06-27-18 at 10:12 AM ----------
Originally posted by stevebrot since the Pentax side (TX) does not support manual flash 2nd-curtain sync,
the troubleshooting thread i linked has people firing second curtain in manual, and in fact complaining that’s All they can do, with flashes supporting P-TTL. if the pop is happening only on manual and not on TTL (they describe getting only preflash and first curtain), that suggests the two are different processes.
Quote: I suspect that the body sends its settings and lets the flash figure out the details once the pre-flash is calculated.
that’s not happening instantaneously on two pins over radio. also, through the lens meansthrough the lens – the camera sends start and stop after determining when there’s enough light.
