06-07-2018, 07:42 AM   #1
Robin's Avatar
Lens Compatability
This is a suggestion for the administrators. Would it be possible to add a FF or DA tag, to the lens profiles, in lens reviews? It's not always clear, particularly with third party lenses, if they are full frame compatible.
Thank you.
06-07-2018, 09:09 AM - 1 Like   #2
QuoteOriginally posted by Robin Quote
Thank you.
This is already supported (and displayed in the spec tables when available). You can quickly filter through full frame only lenses here:
Pentax Lens Search | PentaxForums.com
06-07-2018, 11:30 AM   #3
angerdan's Avatar
And that're just the offical supported lenses. Some like the DA 35, DA 40, DA 50, DA 70 are FF too.
RiceHigh's Pentax Blog: Compatibility of DA Lenses on Full Frame
06-09-2018, 02:23 AM   #4
Robin's Avatar
Tanks guys!
06-14-2018, 08:31 PM   #5
Class A's Avatar
QuoteOriginally posted by angerdan Quote
The DA 40 and DA 70 are not bona fide FF lenses. Some find them usable, in particular in 1:1 crop mode, but they deliver a compromised performance on the full FF frame.
I don't have any problem with people not worrying about the optical shortcomings outside the APS-C image circle, but one cannot simply state that these lenses are FF lenses with a DA moniker.
N.B., for sure some DA lenses could carry a D-FA moniker without any issue because they are based on FF designs, for instance. The DA 40 and DA 70 were always designed for APS-C, though and clearly struggle on FF (beyond benign issues like vignetting).
07-31-2020, 09:25 PM   #6
swanlefitte's Avatar
Here is a list of some lenses for pentax apsc with pictures on full frame. RiceHigh's Pentax Blog: Compatibility of DA Lenses on Full Frame
The 20-40 isn't there but it probably is good around 30-40 with increasing vignette as you approach 20mm
08-01-2020, 08:22 AM - 1 Like   #7
Robin's Avatar
QuoteOriginally posted by swanlefitte Quote
Thank you Chris. I'm still hunting for something really wide (20mm or less) that won't cost as much as a small car... To be a Pentaxian in SA means being a master of surfing the second-hand sites
24x36mm, combatibilty, ff, full-frame, lens, pentax
Lens Compatability ist dl djscutari Pentax DSLR Discussion 5 08-26-2015 11:41 PM
K-3 lens compatability pandora Pentax K-3 11 01-18-2015 04:43 AM
Old lenses compatability for digital SLR pointandshoot Pentax SLR Lens Discussion 14 05-30-2012 03:20 PM
help with lens compatability between models stephenamore Pentax SLR Lens Discussion 11 10-29-2011 04:12 PM
lens compatability confusion runes Pentax SLR Lens Discussion 7 12-03-2009 07:05 PM
All times are GMT -7. The time now is 09:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
