Originally posted by mlaird If the K1 produces the same quality or better when shot in crop mode as compared to my K5, I wouldn't have to worry about the loss of telephoto range by going to full-frame.
Both will produce a 16MP image. Technology advances between the K5 and K1 should give the K1 the edge, but i doubt anyone could tell the difference for normal web viewing.
As far as "losing" telephoto range by moving to FF, you won't. A lens produces the same magnification at the sensor whatever format it is mounted on. A FF sensor captures a wider field of view, not a less magnified image. Cropping the FF image in PP or using the K1 crop mode will yield the same image as the K5.
What will make a difference is the pixel density of the sensor. So a K3/KP (24MP) for example has a higher pixel density than the K5/K1. This will mean you can crop the image more without pixellation. If at some future date Pentax releases a much higher MP FF camera that has for example 30MP in crop mode, you can say that your telephoto has "more reach" on that camera than on the K5/KP
