Originally posted by tibbitts I think the difference is still "grain" in the sense of noise, plus sharpness, plus depth of field. Comparisons are model-depended, though - for example if you compare a higher pixel count APS vs. a lower pixel count full frame, that's a complicated comparison.
When you say sharpness, do you mean "FF is sharper than APS-C"?
Gesendet von meinem Mi A1 mit Tapatalk
---------- Post added 06-18-18 at 10:54 PM ----------
Originally posted by northcoastgreg You can't put a number on the difference between full-frame and APS-C. Full-frame is "better." How much better is largely subjective. Some people find the difference quite dramatic. Others not so much. I'm in the latter group. While I recognize the superiority of FF to APS-C, in actual practice, I don't see much difference. I go twice a month to a photo critique held by the local camera club. I see all kinds of photos, printed anywhere from 14 to 20 inches in size. At that size, you can't tell what kind of camera shot the pics. At that size, we've been fooled by iphone photos. At larger print sizes, all other things being equal, FF has an advantage — though perhaps not as big an advantage as some imagine. There's also an ISO and narrow DOF advantage with FF that some people find decisive to their photography.
This is so true. Smartphones have become very capable of delivering excellent results. Their limitations keep being the same. Pixel pitch with it's limitations and print size, maybe their fixed focal length. Noise and low light are their bane. But at the end it's the end result what matters.
Depth of field really is the same for any format at the same focal length and settings, it's just that smaller formats are like cropping (or "zooming in") on an image. That makes the apparent DOF narrower for bigger formats.
Continuing with that idea, a smaller sensor requires a faster lens for the same apparent DOF, but benefits from the added light gathering capacity. You can see that by comparing MF or even LF lenses with FF lenses. They are considerably slower. F/2 lenses are quite rare on MF, while F/1.4 lenses are quite common on 35mm, F/1.2 not so much but even F/1.0 lenses exist.
OOH, you have a lighter system and that means taking pictures longer, hiking further or just getting less tired. OTOH, you deal with more noise and less low light quality images. That doesn't mean APS-C is bad. Quite the contrary. Systems have become so good you can get profesional results with any format. It just depends on specific needs and cost effectiveness. Captivating images always have and will keep being a result of a good photographer rather than his gear.
