Originally posted by jheu02 As I have no place local to handle any of the current Pentax offerings, which might "feel" better in hands that are used to the K20D body? I've read a lot of comments about the K1 just having the right feel and ergonomics. Any of you used all 3: K20, K-3III, and K1II?
I went from a K10D to the K3-II smoothly. The biggest +impact = difference = improvement was the iso range. Much better low light performance. Feel was roughly the same...some new menu options/features to learn. K3III I expect similar as upgrade, same body size but even more iso range, improved autofocus and newer menus/features. But handling and lens behaviour would be similar, both have Aps-c sensor, same size,...
I think K1 would feel more "larger/ heavier/different".. as it is fullframe camera , and your existing lenses would suddenly yield ”wider” view ,
and if you have DA lenses they would only work in cropped mode (lower resolution) on K1 or cause vignetting....
Hence the change from Aps-c K20 to fullframe K1II, might feel quite less familiar....,
If you used 35mm film before your K-20, then the K1II is maybe closer , same lens-view angle behaviour but IMHO many film bodies were lighter than newer digital bodies.
In both cases K3 or K1: the image files get bigger due to the increase in megapixels, you will need larger and faster sdcards...and larger home file storage.
---------- Post added 09-18-22 at 02:40 PM ----------
Originally posted by rvandenbrink I shoot a KP, and am kinda hoping for a K3 set of features in a new KP, or at least a K3miv with a tilt screen. A K1 just seems like a LOT of camera to carry, especially on a bike
That being said, there’s a lot to be said for a FF 50-60mp camera, if one should come out I’d be pretty interested, esp if they fixed the slow AF and went with a (much) faster storage media
I would say also for an Aps-c 50-60 mpixel camera...
