Sounds to me like it isn’t talking to the lenses properly...
Does lens aperture show up in your exif data? Or ‘F-‘?
If you get ‘F-‘...
If you are using older (pre-‘A’) lenses, they won’t meter correctly unless they are wide open or you use green button metering. You also should have ‘use aperture ring’ turned on in the options.
With newer lenses, it could be dirty terminals. If your ‘A’ or newer lenses have aperture rings, make sure they are on ‘A’
If the aperture shows up in the exif, you’ll need to revisit meter and ISO settings. First step there is also the exif... if you’re shooting iso 32000 outside at 1/100, everything will be overexposed unless it’s night... I may have done that
I’d try those things first...
-Eric
