Show Printable Version 8 Likes Search this Thread
03-23-2019, 02:36 PM - 1 Like   #1
Confused ?!? SMC Pentax-DA* 55mm F1.4 SDM - declared as FF by Yvon Bourque
Hello
In his eBook about the K-1 Mr. Yvon Bourque declared that the SMC Pentax-DA* 55mm F1.4 SDM is FF compatible on the K-1
In Chapter 4 you can read; The Image circle is compatible with Full Frame sensor
I am a little bit confused about this statement! What is true?
Gérard
03-23-2019, 02:47 PM - 2 Likes   #2
Otis Memorial Pentaxian
clackers's Avatar
It's been discussed in this forum many times, Gerard, many DA primes are, and so are several zooms at various focal lengths.
Proof?
I shot this just yesterday with my DA*55 on the K-1:
PENTAX K-1  Photo
03-23-2019, 03:11 PM   #3
Sluggo's Avatar
QuoteOriginally posted by Gerard_Dirks Quote
What is true?
This page is worth a read: Full Frame Coverage of DA Lenses: Comprehensive Test
It's a question of whether the output of a lens fully covers the sensor without significant distortions (like vignetting or color aberrations). In this case, it almost does, except at the widest apertures there is just a little bit of vignetting.
When you are shooting portraits -- a common job of the DA*55 -- some vignetting is not always a bad thing; so in practice most users feel the lens is useful on full frame. Pentax won't call it officially compatible though.
03-23-2019, 03:56 PM   #4
Yes it can be used on a FF body. You might want to get an off brand shorter hood.
some even compare it with the new DA*50 which it perform pretty well.
SLRCLUB, ??? ???? ?? ????
That page is one of the reason I buy it.
03-23-2019, 04:06 PM   #5
aurele's Avatar
it is. works flawlessly on the K1.
03-23-2019, 04:35 PM   #6
sbh
sbh's Avatar
It's a very fine lens with beautyful and unique image character. Unmatched by any other lens (except the Fat Fifty), neither star nor ltd lenses.
It works on the K-1. The only shortcomings on ff I noticed are slightly softer corners obviously, and also noticeable vignetting when focussing at closer distances like 2m (6 ft) or less. I've tested it against a white wall. Other than that, I see no reason not to use it in ff.
03-23-2019, 04:39 PM - 1 Like   #7
clackers's Avatar
I'm going to guess it vignettes *less* than the FA50 f1.4 and the FA31 Limited.
03-23-2019, 05:21 PM - 3 Likes   #8
Sandy Hancock's Avatar
Strictly speaking, it's not 100% FF compatible. At some focal distances and apertures, a tiny "physical" vignette (i.e. black corners with no recoverable detail) may occur. That is why Pentax have not declared it officially as a FF lens, like they have for the DA*200, DA*300 and DA560.
But as clackers and aurele have already stated, image quality is good to the corners and generally speaking, "optical" vignetting (completely correctable in post-processing) is negligible. It is a very useful and enjoyable lens on the K-1.
There is an album full of images HERE if you're interested.
03-24-2019, 03:20 AM   #9
pschlute's Avatar
On the K-1 the lens will be able to use Lens-Correction features (distortion correction etc) when used in crop mode only, not in FF. But with a lens of this focal length and quality I would say that is irrelevant.
03-24-2019, 04:23 AM   #10
THX a lot for all the response
I uses Pentax since 1975 and what I always love was the (light-weight) of their body. I have very much old glass and still use it. Also an SMC Pentax-A 1.4/50mm.
I loved my Super A & LX an never could find a friendship to the film-area body. I owned a Z-1p and I really used it maybe for only 50 films
The K-1 is a heavyweight compared to my K-3 & K-5 bodies and I refuse to add another 750gr more for an new HD D FA* 50mm F1.4 SDM AW. If the new has 1.2 it would the weight be OK, but not for an 1.4
Therefore I look to both the SMC Pentax-FA 50mm F1.4 oder the SMC Pentax-DA* 55mm F1.4 SDM. The first is very compact and tiny, 1.4/55mm some more impressive and still a lightweight compared to the newest 1.4/50mm
Which Lenshood will be the best to fit on the 1.4/55mm & K-1 and will not cause vignettering? I don't want a rubber one! Will this fit Sensei 58mm Screw-on Tulip Lens Hood LHSC-58 B&H Photo Video
Gérard
03-24-2019, 04:33 AM   #11
When I got my first K-1 I tested my DA*55 with hood on and hood off. It made minimal difference.
03-24-2019, 04:40 AM   #12
normhead's Avatar
Hello
Gérard
Absolutely true, I have third party lens hood on mine.
Virtually no vignetting even at ƒ1.4. And great lens on a K-1 as well for those who want better than average quality at less cost and weight than a 50 1.4.
03-25-2019, 02:49 PM   #13
Wheatfield's Avatar
Hello
Gérard
After I had been using my K1 for long enough that I knew that I wouldn’t be going back to APS-C ever, I had a hard look at whether or not to keep the DA* 55mm. One of the things I did was check it for vignetting and I noted that wide open down to around f/2.8 there was slight falloff, but nothing too major. However, it was there, and it was too great for Pentax to be able to call it a full frame lens.
My biggest beef with it was I found the bokeh to be a little odd.
Anyway, I sold the thing and did find myself regretting that I had as even with its faults it was still better than the FA 50/1.4. After the D FA* 50mm was released I stopped missing it.
05-06-2019, 05:11 AM - 1 Like   #14
bdery's Avatar
See here:
Modern Fast 50mm Shootout - Review Announcements | PentaxForums.com
While not perfect, it's fully FF compatible, and a valid solution for a high-quality WR and AF 550-ish lens.
05-14-2019, 03:10 PM   #15
pid
Gérard
I use a ventilated lens hood like this one: 58mm ventilated lens hood
With this hood you can use your original lens cap!
24x36mm, 55mm, bourque, f1.4, ff, full-frame, k-1, pentax, pentax-da*, sdm, smc, yvon
Pentax K-1 e-book by Yvon Bourque ebooks4pentax Pentax K-1 & K-1 II 5 12-29-2019 06:45 PM
Yvon Bourque's K-70 Book. Is it worth it? Just my opinion. gump Pentax K-70 & KF 11 08-26-2018 12:46 PM
Yvon Bourque has released his Pentax K-70 ebook SeaRefractor Pentax K-70 & KF 3 06-27-2017 12:20 PM
For Sale - Sold: Pentax K10D Book by Yvon Bourque rfortson Sold Items 2 08-09-2008 12:58 PM
All times are GMT -7. The time now is 01:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
