I shoot everything at -.7 EV, then move the EV dial up and down until I have the image histogram the way i want it.
But to maintain shadow detail that looks good I like -1 EV.
But there are conditions where -2 is necessary.
You want the DR centred on the sky, the darker elements are relatively un-important.
It's dark, you want it to look dark
2019-04-05-minus-2-EV- 1 by
Norm Head, on Flickr
I had to go dark to keep the dock from being blown out.
Subject in the shade, light background.
Subject is in bright sunlight, back ground is in shadow.
This is a decision I make checking the histogram and the image when chimping, and for every image I have another one taken with no EV compensation just as good taken in similar circumstance. The DR of the K-1 makes this a lot less critical, but if you do pay attention to your EV setting, you can get better images. Most of the time, I've bracketed and then selected the best images, and the images range from -3 to plus 1 can be found in my photos, but usually .7 EV gives me the best result. I haven't found a rule for how this works. It's always trial and error.
It's also surprising looking at the K-1 images, how many images are taken at -0.7 to 0 EV. The increased DR of the K-1 has meant less, tinkering with the EV button. I have very few exposures that required radical adjustment since I stopped using the K-3 for landscape and started using the K-1.
