07-03-2019, 01:17 AM   #16
QuoteOriginally posted by landofcourtness Quote
If I had to prioritize (would seem like a pretty good kit): 28-105, Macro, 70-200, 24-70
Wouldn't the 24–70 + 100mm macro negate the need for 28–105? With such kit the only niche that the 28–105 would fill would be a single walk-around lens.
07-03-2019, 03:03 PM   #17
TLDR: I can't say enough about how much I feel like I learned from having 28-105, in terms of framing + especially in terms of which lens(es) to get next. I'm not sure I would have gotten without that specific lens... and because its still useful and a steal at $350.
I do think that both of them in tandem would cover most (if not all) of the important ranges from 28-105... but I will say that I do think that a person should start with the more affordable options... but also, when first getting a K-1, I do think that its difficult to replace the versatility that exists with the 28-105. Coming from an APS-C kit, I think I learned a lot about how I composed things differently (the 1.5x crop factor does make a pretty big difference), and while you're trying to figure out what/where to go with my next lens... I'm not so sure I would have learned as much if I didn't have that specific lens.
I myself, also really hates buying lenses too that eventually just become obsolete... but even though I have my 24-70 + Tam 90mm... I do keep going back to the 28-105. As a single walk-around I do think that it has value as that. You can make the argument that it is only 30mm, but I would say that there is a lot that you get in that distance. I think out of all of my lenses: Sig 17-35 2.8-4, 35 1.4, 70-200 HSM II 2.8, 150-500 4.5-6.3(?), Pentax 24-70, 28-105, Tam 90mm. If I could only choose one lens to leave the house with, I'd probably grab the 28-105 in most situations (prob 3rd most used). I definitely use it more than my 90 for sure. If I didn't shoot so many of my school events, I'm sure it would be used more than the 70-200. Only if it were night or I knew that the bulk of shooting was done at night would I opt for something else. The only other caveat is that I'd probably never choose it when I do Professional/Events, since light changes so often. I also really like it on my K-3 when I'm double-shooting outside. The 44-157 is really great when paired with the 35 or 24-70 on my K-1.
07-03-2019, 03:17 PM - 1 Like   #18
Thanks all, I've purchased a used 28-105 as a result of all the praise which will hopefully arrive tomorrow. I'm a bit of a pixel peeper so hopefully it's sharp enough!
I think the 77mm is next on my list as a nice fast portrait lens similar to the 50mm crop.
I'll probably drop by a few stores next time I'm in the US or Japan and see which lenses I like.
07-07-2019, 10:57 AM   #19
The limited 70mm 2.4 works very well with the K1. I liked the option of the cropping but also worked fine as full frame. On light trips i would just carry the above and the voigtlander 20mm 3.5.
Probably get both of these for the price of the 77mm limited.
09-03-2019, 05:58 PM   #20
TerryL's Avatar
QuoteOriginally posted by ReadyAimPhoto Quote
Hey FF gang
I recently picked up a used K-1 (coming from a K-3 ii) from MPB and got an amazing deal. I've had my eye on the K-1 since it was announced as I love landscape photography and milky way shots.
I've done a tonne of research around FF lenses and I'm a little spoilt for choice it seems. There seem to be a lot of comparisons between various FF lenses such as the FA 50 1.4 and 1.7 but I'm struggling to find comparisons with FF compatible DA lenses like the 50 1.8.
My current lens setup is as follows and I'm trying to work out which to upgrade and which to hang onto:
Sigma 17-50 EX HSM - picked this up as a walk around lens and was really unimpressed with it. Will definitely be selling this as it doesn't cover the FF sensor.
Pentax 50mm f1.8 - easily my favourite lens on the K-3, super sharp and great bokeh. Considering replacing this with a F1.4/1.7
Pentax 35mm f2.4 - slight vignetting on FF wide open but definitely usable. I generally use this as my walkaround as it's far sharper than the Sigma although if I get a 24-70 or 28-105 I doubt I'd get any use out of a 35mm prime.
Samyang 14mm f2.8 - my go to astro/landscape lens. Definitely keeping this one and can't wait to see how milky way shots come out on the K-1.
DA 55-300mm - I don't get too much use out of this so it seems a waste to upgrade. Definitely feels usable on the K-1 either in crop mode or with post cropping in FF. Nice to have for the odd wildlife shot I guess and much lighter than FF equivalents.
With the 50mm being my favourite lens on the K-3 I'm thinking about getting the 77 limited and either the FA 50 1.4 or 1.7 (although I might struggle to pick the 1.7 up in the UK).
My local Jessops/Wex stock very few, if any Pentax lenses so testing them out before buying is pretty difficult.
I'm interested to hear which lenses everyone here thinks I should prioritise and any I've missed! I definitely won't be buying all these lenses straight away as some of them are pretty pricey!
Cheers all!
D FA 50 f/1.4, D FA 24-70, D FA 15-30 DA 200 & DA 300 are also officially full frame compatible.
09-03-2019, 09:41 PM   #21
pres589's Avatar
If I had a K-1 right now today, by pres589;
Tamron 17-35
Pentax 28-105
Pentax M-series 20mm f4
Sigma 24mm f2.8 Super-Wide II AF
Pentax FA Ltd 43mm
Pentax DA 70
Pentax F 135mm f2.8
Pentax DA 55-300 RE
The end.
09-04-2019, 12:58 AM   #22
I think you are good to go with the prime lenses you have.
14, 35, 50mm.
If you enjoy primes more, then look for a FA28/2.8.
Maybe something longer for portraits, so the FA77ltd is really the only and best AF option readily avaliable.
09-04-2019, 03:30 AM - 2 Likes   #23
One lens to consider is the DA *55. I think it is better than the FA 50 on full frame. I know it isn't officially listed as full frame by Pentax, but other than weak corners wide open it is pretty good and the FA 50 is worse till f2.8 too. Biggest negative of it is the slow SDM auto focus.
The FA limiteds and the DFA 100 macro are all excellent lenses too that should be considered, particularly if you can find them for a good price used. The FA 35 f2 is a good lens that should be considered if you don't find the corners adequate on your DA 35 and don't want to spend a fortune on the Sigma 35 f1.4 or Pentax FA 31 limited. I wouldn't spend a bunch more on zooms. The DFA 28-105 will cover basic needs and hopefully down the road Pentax will come out with a variable aperture 70-300 zoom that is full frame compatible.
09-11-2019, 01:17 AM - 1 Like   #24
johnha's Avatar
My K-1 kit is basically FA20-35/4, FA43, and something longer like an M135/3.5, M75-150/4 or M80-200/4.5 (I need aperture rings for film cameras). I didn't buy the DFA28-105 as I have loads of old 28-xx zooms and can't justify another. I would like something weather sealed, but don't need anything longer than 43 or 50 until about 135 where I often want something in the 150 or 200 range. I dislike heavy lenses on cameras unless I need longer reach.
09-11-2019, 01:44 AM   #25
Sandy Hancock's Avatar
Your DA35 and DA50 plastic fantastics will work well enough for starters.
The Rokinon 14mm is a full frame lens, so not problem at all there.
The DFA28-105 is simply brilliant.
For occasional telephoto use, stick with your 55-300 for now. Its weaknesses will become apparent, and their importance will determine how you deal with the problem.
09-11-2019, 01:47 AM   #26
Good work - sorry to interject the thread but, if you don't mind my asking, how much did it set you back?
09-11-2019, 06:47 AM   #27
PEG Moderator
Kerrowdown's Avatar
Any of the faster "Ladies" from my harem, provided you can live with manual focus.
09-23-2019, 07:21 AM - 1 Like   #28
Hello ! I got a like-new used DFA 28-105 last spring to use on my K1. Best lens for landscape I ever bought.
10-19-2019, 08:45 PM   #29
Gerbermiester's Avatar
If you like the look of the da 50mm f/1.8 on a K-3, you'll love the FA* 77mm on a K-1 (I know that I do!). If you are looking for a replacement for your 35mm's look on full frame, just hang onto your da 50mm for a while. It's not excellent in the corners, but it still makes great photos on a K-1. Here's an example of the Da 50mm f/1.8 wide open on my K-1.
(I ended up swapping the Da 1.8 for a FA 50mm f/1.4 later. But, honestly, I wouldn't be in a rush to be rid of it.
I typically shoot the Fa lens at f/2 or slower, since I dislike the rendering and softness it shows wide open).
10-20-2019, 04:49 PM   #30
Journeyman Cat Wrangler
SSGGeezer's Avatar
I have to agree with Rondec here, the DA* 55 is amazing on a K-1! AS he stated, wide open there is noticeable vignetting , but by f/2.8 it is barely noticeable and by f/4 it is gone. It isn't that slow to focus either, and it is great for walking around with the same sort of focal length set up you would have had in a film DSLR. I haven't tried it on my KP yet because it is so nice on the K-1. Find a deal here and you won't regret it.
24x36mm, 35mm, 50mm, fa, favourite, ff, full-frame, k-1, k-3, lens, lenses, pentax
Ultra-Wide on FF: Which lens(es) to keep and which to sell? Docrwm Pentax SLR Lens Discussion 17 04-03-2019 05:56 AM
To change mount, or not to change mount? IgorZ Troubleshooting and Beginner Help 6 10-09-2018 01:34 PM
The effect of Perfect Sun star in which Pentax Lens? switched Canon User for 10 years Majeed Troubleshooting and Beginner Help 9 01-02-2017 07:54 AM
I switched to FF Lurch Pentax Full Frame 81 03-06-2014 02:42 PM
To change lenses or not to change lenses. That is the question. atyab Photographic Technique 28 11-24-2008 09:27 AM
All times are GMT -7. The time now is 08:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
