Originally posted by savoche You also will not get your best images in broad daylight. Not only because the predators will tend to be asleep in the shade, but also because the light will be harsh. My top tip is to get up early, leave camp as early as they will allow you to. A lot of my best sightings have been in that first hour after sunrise. Yes, you might have to get up at 5, but you don't want to miss the best part of the day.
Just around sunset can be good too, but in most parks you have to be back in camp before sunset - which means you will have to leave that pack of lions behind just as they are getting ready to move! I believe night drives are not allowed in the Mara - at least it wasn't. Some parks and reserves in Southern Africa do allow it, as do most private concessions.
Anyway, don't be surprised if you have to raise your ISO to 6,400 (or above) for some of those early morning/late afternoon shots. With long lenses and animals on the move you will want to keep your shutter speed up.
Thank you @savoche for your important tips.
In effect, if I need to factor in making images at ISO 6400, for the times when the animals are active in low light, is more likely, that rules out the poor old Canon 50D. It just can't manage beyond 400 ISO as i am learning. Despite the age, it has other good things about it like a good frame rate etc. In broad daylight, it might still save the day.
It looks like i should forget about the 50D. Maybe i could give it to my son to start learning photography.
---------- Post added 08-02-19 at 08:48 AM ----------
Originally posted by normhead A Tammy or Sigma 300 2.8 is a wonderful thing. With the 1.4 TC in your pocket giving you extra length if you need it, ( 420 ƒ4, 630mm ƒ4 equivalent on FF ) you can do almost anything. But honestly, for my wildlife shooting, I've done a lot with the DA* 60-250, also with the 1.4 TC in my pocket or on the camera. I even have some images taken with my DA 18-135.
DA* 60-250 notice, this is shot at 88mm.
K-3 and Tamron 300 2.8 with 1.7x AF adapter. 520mm ƒ4.5
DA* 200 2.8
ƒ2.8 - ƒ4 definitely have their advantages.
And claiming Pentax AF won't be up for the job is nonsense.
Above: One rare moment with a moving target, three shots, two keepers, nailed it. With "slow Pentax AF and a slow focussing DA*60-250.
There is a huge amount of BS on the internet. The funny thing is, it doesn't matter who many times you prove people wrong, they just keep repeating the nonsense.
Or as Bart Simpson would say "Eat my shorts."
It may well be, more expensive cameras may be better, for some purposes. The chance that you actually will encounter one of those events that requires better than Pentax AF is a lot less likely than some people make out. But if you're interested in spending 5x as much money for the 5% pentax can't handle that's probably about $2000 for each percentage increase (because your not getting 100% with any system,) go for it. It's your money.
Buying a better system with more AF points etc can be a thing. Saying you have to go that route is nonsense.
Thank you @normhead for the detailed post. And for sharing such wonderful pictures.
I agree with you completely. The limitation is the man behind the camera in most circumstances. Second, you can't have it all (even if you have all the money) in any camera system. Third, less is more at times. Fourth, beyond all the noise, Pentax AF is good enough for me. Fifth, I am just not into high speed wildlife photography. It doesn't appeal to me that i shoot frantically and hope for some decent images. I would like to shoot less and deliberately. I can use my buffer limit on the K1/ K3 judiciously. Sixth, it is an intuitive design. I have never delved into the 645Z menu after the initial set up. The buttons and dials do it all for me. It is a more efficient and likeable way of using the camera and i don't expect the K1/ K3 to be any different. Seventh, the pixel shift feature opens great possibilities. Eighth, every single lens sort of becomes image stabilised because of the IBIS. Ninth, i can use the outstanding 645 lenses on the K1. Finally, Pentax is rationally priced.
I really wonder why i should now even think of any other camera system
I guess i have mostly made up my mind. Advice by many members has been useful. When your financial means are limited and photography is not a profession for you, it is important to be judicious in spending money. I must thank all of you who have taken your precious time in giving your comments.
I just have this one crucial question about the APS-C mode of the K1:
Does APS-C mode in K1 essentially transform it into another camera body akin to say K3, with accompanying benefits of higher buffer? (BTW, I spoke to a guy who owns the 5D and 5R. He says there is no APS-C mode in 5D but it is there in 5R).
If THE answer to this question is Yes, even if in a roundabout way, it is a game changer and then there is no motivation to think of the K3 or the KP. I will just buy the K1 and use it in APS-C mode whenever i have to.
Thank you all once again.
